Just completed my first MoI project...
All  1-5  6-12
4670.6
RE: FACETTED BRIDGES
The workflow for the above renders was MoI --> .igs --> Alibre --> .bip --> Keyshot. The facetting seen in the renders is, imo, the result of a bug in Alibre.
To confirm this I imported the iges into PowerMILL i.e. MoI --> .igs --> PowerMILL and the result... no facets.
4670.7 In reply to 4670.6
Hi bigseb,
The thing is, when you convert into .bip format, the geometry in the .bip will actually contain 100% triangular facets in it.
You just won't be able to notice it as much in areas where a lot of facets were generated.
Many meshing engines have various parameters in them that control how the meshing engine will decide for whether to subdivide things into more facets in a particular area or not.
If there are any mesh generation settings like that available for you to tweak, you could possibly solve the bug by adjusting those parameters.
4670.8 In reply to 4670.7
Hi BigSeb>> Regarding triangulation in Alibre...
You probably already know this but have you tried increasing 'curve smoothness' display setting in Alibre before you export? Here are two identical files rendered in Keyshot 'wireframe' from Alibre. The first set at 'coarse', the second at 'Fine'.
4670.9 In reply to 4670.8
Are you stuck with your keyshot only opening files from Alibre? Use MoI as the mesher. It is far superior!
Models going to Alibre? Send them as STEP or ACIS over IGES.
PowerMill is opening your NURBS surfaces. It's not meshiing them.
4670.10
Al,
My settings are always at fine.
Burrman,
I will try step later today. Thanks.
4670.11 In reply to 4670.9
Unfortunately I think I remember hearing that the Keyshot version that comes bundled with Alibre does not have all the same regular import file support as the regular version does, like it doesn't support OBJ import.
So basically with those importers stripped out you're forced to go through Alibre for generating the mesh into Keyshot's own .bip format and can't use MoI's mesh exporter instead...
At least I think that may be the case.
4670.12 In reply to 4670.11
Its true. My Keyshot only imports/opens bip files.
Show messages: All  1-5  6-12
