Script Error
All  1  2-4
4669.2 In reply to 4669.1
Hi Sharif, it looks like that particular script on Petr's page got mangled - it's probably some of the HTML tags in the script itself are being seen as web browser content or something like that - anyway a little piece of the script is actually missing there.
Get the full script from the post here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=2703.12
and then that should work in both v2 and v3.
4669.3 In reply to 4669.2
Hi Michael;
Thanks, It worked with new script. I was wondering if this script can be modified to get the length of any curve after it has been drawn. For example, if I draw an ellipse and later on I want to find out the circumference of the ellipse; something similar to "List" command in Autocad.
-Sharif
4669.4 In reply to 4669.3
Hi Sharif - there is another script on Petr's page just above that other one which will let you get the length of a curve that has already been drawn:
http://kyticka.webzdarma.cz/3d/moi/#CurveLength
At some point in v3 I want to make a kind of extended properties dialog that will be able to contain a bunch of information like that in the UI.
Show messages: All  1  2-4
