V3 beta Oct-25-2011 available now
 1-7  8-23
4665.8 In reply to 4665.7
That new cplane feature is so awesome and clever ! Thanks :)
4665.9 In reply to 4665.7
Hi ed,
> It works really nice, the only difference is I imagined it
> with more visual feedback like a grid appearing.
The problem I would see with that, is that it could really surprise someone who was only creating construction lines for some other purpose.
I can't be sure that in every case that you create 2 crossing construction lines that you also want to completely change the entire grid after that.
What if for example someone makes 2 crossing construction lines at the end of the curve to put out some tangent and perpendicular extension lines but then still wants to draw a freeform curve with some of the interior points of the curve aligned to the current grid?
I must translate that as soon as possible !
Done on the French Forum just now copy past to the Wiki :)
4665.12
I see. For new users it can be confusing, but in the case you mention above if you know what happen when you make two clines from the same point you can just make the second cline from another point to the start of the first. But you know better than I what is better.
4665.13
Hi everybody!
Just a question. Is there the possibility to have more options on "line styles" (i.e. line thickness and pattern) on new V3 version?
I think it's very important such an option.
<< Just a question. Is there the possibility to have more options on "line styles" (i.e. line thickness and pattern) on new V3 version?
You can since the V1 ;)
http://moi3d.com/forum/messages.php?webtag=MOI&msg=1049.17 (scroll)
EDITED: 3 Nov 2011 by PILOU
4665.15 In reply to 4665.13
Hi miquik,
> on new V3 version?
Do you mean more choices for some of the current settings like the line style for the grid display?
Or are you talking about a way to apply different line styles to shapes that you have drawn?
I do want to implement a line style mechanism to be able to apply different styles to your objects but I'm not sure right now if that will happen in v3 or not.
4665.16 In reply to 4665.15
I'm talking about apply different line styles to shapes. I'd like to use your software for produce "technical drawing" (for "end user manual") in my company and for me it's very important to have different line style (i.e. silhouette edges, line patterns, etc). Also filling surface with "hatch style" will be great.
Do you think it will be possible? Maybe in the future in version 4.0? :-)
4665.17 In reply to 4665.16
Hi miquik, yes I would like to get to that point but it's really hard to know exactly when it will happen. V4 is far enough out that saying anything about it would be just random guesses...
There are kind of several stages of things that need to happen before even having line styles to make technical drawing production work well, one of them is generating hidden line drawings which I want to try and work on for v3.
4665.18 In reply to 4665.17
Yes, I understand your point and I agree with you that transform your (great) product in a REAL technical drawing software would require a huge modification.
It would be great, but my request is somehow simplier. For me it's enough to be able to change manually line style and hatching to simulate silhouette edge and hidden lines.
We currently do in this way (using autocad 2d for 3d drawings!).
4665.19 In reply to 4665.18
Hi miquik,
Right, but what would you then do with your model in MoI that had lines styles and hatching just only visible on the screen, just look at it and nothing else?
Probably there are various other feature areas that go along with that, like generating image output and printing, are you really sure that simply changing the line style only inside the viewport alone would really get you what you need?
The next step for this area I think will be making it easier to generate a hidden-line vector drawing which will then make it easier to use MoI in combination with a 2D program for doing the styles and hatching. At some point I do want to have all that stuff included directly in MoI itself at least at a basic level but I think that it's a much larger amount of work and involves several intertwined features to a bigger level than what you may really be thinking...
Notes about the V3 inside Wiki : done ;)
http://moi3d.com/wiki/Notes_au_sujet_de_la_V3
4665.21
Hi Michael G.
Are the any plans for v3 that would involve measurement and analysis tools?
Michael T.
4665.22 In reply to 4665.21
Hi Michael T.
I do expect to spend some time in V3 on this general area. I'm not sure right now exactly what will be done for it, but probably there will be some UI for things like volume or curve length calculations.
4665.23 In reply to 4665.22
Thanks Michael G. I have been using the scripts for measuring distances and curve lengths, but volume and area would be sweet :-)
Michael T.
Show messages:  1-7  8-23
