Beginner: Help with blend
 1-4  5-24  25-36
4653.25
Hello,
It's like a speed painting tutorial, only with MoI.
4653.26
Guys
I have created a simple model and wishing to connect the cylinder.
Now I know this is a candidate for the blend tool and it does works. However I having a brain block how to merge it into one object
Once I apply the blend tool, and attempt and boolean Union the cylinder still refuses to merge into one cylinder.
Steve
4653.27
Hello Stever_uk,
After your Blend try selecting the three pieces and selecting Join.
4653.28 In reply to 4653.26
Hi Steve,
Thats a "Join" with those 3 surfaces...
A boolean is geared towards having 2 solids that intersect somehow and creating a new volume by calculating the new intersections and removing the unwanted pieces. The Join is how various surfaces are "Glued together". If you have 2 surfaces with a shared edge, then they can be joined at that edge. With proper construction of surfaces, having all edges joined into a closed shape, creates a solid.
4653.29 In reply to 4653.28
Hiya,
That's what I thought as they were faces. I do a join but I still see the two edges within the cylinder and thus don't believed they have have joined into a single object
Steve
4653.30 In reply to 4653.29
When you select your object, look at the properties in the upper right corner:
4653.31 In reply to 4653.30
Gotcha, ok so I have formed a solid
I was just expected the lines in the cylinder to disappear
Thanks for your patience :)
4653.32 In reply to 4653.31
Hi Steve, so those lines are the surface edges - when you do a join what actually happens is the edges get glued to one another, so join will not make edges disappear the edges are still there but now MoI will have knowledge that there is a connection between the pieces on either side of the edge.
If all the edges of an object are joined between 2 surfaces that makes a fully connected skin and then forms a solid volume.
Edges are not normally things that you get rid of, they're boundaries of a surface. To get rid of an edge would mean building a bigger surface in that spot rather than having several small surface pieces.
If you want a final result that is missing edges like that, that's usually a sign that you actually want to start out with a bigger piece initially and then cut away some portions of that rather than building that particular area out of little separate surface patches.
4653.33 In reply to 4653.32
Great that makes it all clear now Michael, thanks
4653.34
Hi Michael
..sorry to capture this thread, but there seems to be a problem with the Blend command in the recent beta.
I had this kind of glitch before but in connection with the UI settings. Is there a proper place for reporting bugs and alike anyway?
cheers,
Marco
4653.35 In reply to 4653.34
Hi Marco, yeah that's the same bug as the UI settings one.
But I think it should be fixed in the most recent Oct-25 beta release (which I still haven't made a proper announcement for, will do that soon) which you can download from here: http://moi3d.com/beta.htm
Or do you mean that you're still seeing that bug in the Oct-25 release?
Either here in the forum or you can e-mail them to me at moi@moi3d.com
4653.36 In reply to 4653.35
Hi Michael
silly me..i really have to uninstall the Aug-24 release..gsus..i do have the Oct-25 release installed and everything's fine there. Problem was, that i mixed up the "MOI" from the Start Menu with the "MOI" from the recently opened programs. Maybe displaying a release/version number more prominent would diminish those false alarms.
Case closed!
cheers,
marco
Show messages:  1-4  5-24  25-36
