I'm getting frustrated here! Closed  Locked
 1-8  9-24
4649.9 In reply to 4649.8
I think the Idea behind the selection behavior was to be able to use it with a tablet without constantly needing modifier keys.
Marc
  More Options
4649.10 In reply to 4649.6
Hi JDonner, you haven't taken enough time to understand how some of the most basic stuff works in MoI.
It's not unusual, especially with 3D programs, that you might need to take a few minutes to learn how some stuff like selection works.
In this first case what you are describing here:
quote:
I click on the center of a polygon, part of a cube. All polygons of the cube are selected. I click again; the actual polygon is selected. I click again; nothing is selected. And this is not confusing to newcomers?
That's what's called "drill in" selection - it is what allows you to select sub-objects like a face or an edge. The first click does "whole object" selection, and a second click on the same object will "drill in" and select a sub-object. Then with the 3rd click you're doing deselection, because other than the special case of the initial drill-in, a click on an already selected object will deselect it.
Also yes you're right MoI behaves a bit different with regards to selection than other programs - with MoI you're always in "multiple selection" mode, meaning you don't have to hold down shift or ctrl to select multiple things, it just always does that automatically. That's one of the features of MoI, that you don't have to keep touching the keyboard a million times a day to do basic stuff.
This is all quite clearly and simply described in the documentation selection section here:
http://moi3d.com/2.0/docs/moi_introduction.htm#selection
How is it that you expect me to spend a lot more time writing documentation when you won't even read the short introduction document that already addresses the stuff that you need to know and are complaining about?
  More Options
4649.11 In reply to 4649.8
I still don't understand how you could think that the forum here is difficult to use... I mean it's so simple and streamlined, there's a list of messages, you click on a message thread to read it, you click on "Create new discussion" to, well, create a new discussion.
Is it that I do not have enough animated GIFs and avatar icons everywhere?
I really think that you'd be better off with Bonzai3D which you keep mentioning, you should probably give up trying to use MoI and switch to that instead.
  More Options
4649.12 In reply to 4649.10
Are there any updates for the 2.0 release?
  More Options
4649.13 In reply to 4649.12
No - in general MoI has a long extended beta period with a lot of tuning going into the final release itself. So with that long run up to the final release it's generally a goal of mine to incorporate fixes into that release itself rather than pushing out something that is not very refined and having to patch it up a lot afterwards.
From what you are describing, it sounds like you would prefer to have buggier final release with having to apply patches to them later on instead of solid final releases?
  More Options
4649.14 In reply to 4649.11
I don't understand also, my question all along has been: why aren't other forums like this - simple, focused, with great search functionality.
I hope this isn't the start of occupy MOI :)
  More Options
4649.15
JDonner - Are you more used to polygonal modeling than NURBS based modeling? I am not talking of hypernurbs in C4D because that is polygonal modeling. MOI does not behave like that at all. It is more akin to solid/surface modelers like Rhino, solidworks etc...
It will take a different approach to achieve the same result. For instance this approach to modeling would rarely ever select a polygon or face and attempt to extrude more geometry from it. An approach with this type of software would be to start with a larger chunk of geometry and remove profiles with boolean functions or set up profiles (splines) to use as foundations to create the additional geometry with sweep/extrude/revolve tools.
The only modeler that ever really "bridged the gap" so to speak between the techniques was Amapi/Hexagon which blurred the construction methods of both polygonal and NURBS.
  More Options
4649.16 In reply to 4649.11
I don't know why the two of you keep saying that I claimed that the forum is difficult to use, I never said that. I said that it's an awkward layout. I'm pretty sure that most people, including me, find it just as easy to use as other forums, but that's not why I'm talking about. My complaint is this; why force people to get used to yet another forum layout or way of doing things, why not sticking to what most forums use, so that people are accustomed to it from the start? It reminds me a lot of Flash fanboys that force the most awkward menu layout upon their visitors just for the sake of trying to be different.
  More Options
4649.17 In reply to 4649.16
What on earth is awkward about the forum?
The layout is a list of topics going down the left hand side and then the current discussion thread in the pane to the right.
It's very simple.... It's quite curious that you'd consider it to be awkward.
Really, you've worn out your welcome here with rude behavior just starting from your first post - it seems like you will need a lot of help to get things going and just judging from your behavior in your first post I think it will be a lot of unusually frustrating effort to try and help you, so that suggestion that you give up MoI and use something else like you keep mentioning is really a good idea. Not just for you but for the benefit of all of us here as well.
Thanks very much for your attempt at using MoI and I hope that you will have better success with other software and other discussion forums.
  More Options
4649.18
JD
I was brand new to modeling when I bought Moi. I have tried every program under the sun..this is the simplest..very intuitive. In the begining I watched Michaels tutorials and then just played around a lot. I started really undertanding things when I read the documentaion Michael has. It is a VERY good explanation of each command. When I finally read the documentation..lot of lightbulbs when off. Also sounds like maybe your approaching this from a ploygon standpoint..ie your mention of selcting a polygon...nurbs are totally different. My 2 cents read the documentaion..it's very helpful.
I would hate to see your post about C4D if you have these kind issues with MOI
Michael - you cant please all the people all of the time. I will say this since buying MOi in 08 and reading here alot..this the first time I have seen a bitch slap of Moi.
  More Options
4649.19
"From what you are describing, it sounds like you would prefer to have buggier final release with having to apply patches to them later on instead of solid final releases?"
OMG, stop acting like you're the king of reliable software....seriously!
For your information, I've been working in the IT for almost 24 years, I know all about software and as a matter of fact, I've even been a professional programmer in RPG III/IV on IBM mainframes. Some of the things you said just totally boggles my mind. Let me give you a major wakeup call son;
- a lot of beta testers aren't really serious beta testers. Often they're just curious about the new features and very few take the time to test features that they would never use themselves and often they only take take time to report bugs, if they're affecting THEIR current workflow.
- it's an indisputable fact that the greatest test for any software is the time when it's released and used by thousands or in some cases, millions of users (customers or people who use the trial version), all with different experiences, different configurations, different ways of doing things.
- the huge majority of beta testers are people who already have been using the product for quite some time. You will seldom see them bring up issues that might confuse people who are totally new to the software. You'll be surprised how quick users are, to live with or work around certain shortcomings in the software and simply forget about it over time. They often won't be the ones that point out those shortcomings, only newcomers will and the sad thing often is, when they are pointed out, the long time users often don't take those complaints seriously....after all....they got used to the shortcomings.
- all software of this size and larger contains bugs, PERIOD! Don't act like you're so much more special than anyone else, because you're not. And not only that, also your software will have a few MAJOR bugs that most definitely require an update!
- A lot of updates for a .0 release is NOT a good sign, but having NO updates at all is not a good sign either. Don't pretend that your beta test is so much better than anyone elses, because it's not. No matter which way you want to look at it; MANY potential customers DO look at the update policy of a developer, especially when they require that software for professional purposes. You're just sticking your head in the sand, because all you see is just dollar signs with every major release, updates however are seen by you as a nuisance that don't bring any cash.
I asked if there were any updates, to confirm my suspicions about your so called "support". They are now confirmed. Time to look elsewhere. Bye.
  More Options
4649.20
Michael
Hope you ban this guy..LOL what a troll
  More Options
4649.21 In reply to 4649.20
Sure, a troll takes all that time to write all those long responses. Don't you think it would have been much easier for me to to just say that it sucks? The "It's a troll" is just lame way of immature people like you to respond to anyone who disagrees or shows a dislike. If I were a troll, I would not have taken the time to come up with arguments. The "troll" comments just makes YOU look weak and not me.
Btw, if this program is so "great" as all of you claim, then when does he have so little customers, why isn't it so popular and why are most people willing to spend 2-10 times more on a different product? C'mon tough guys, explain that one to me... unless I'm the one dealing with the trolls. I've learned one thing after 50 years; most great products simply sell itself, period! This one isn't great enough, so it simply doesn't sell. Bye.
  More Options
4649.22
Wise man said:
..."Contention is the spirit of the Devil"...
The Devil never did anything short of promote wickedness, and
"Wickedness never was happiness"
Sad.
  More Options
4649.23 In reply to 4649.19
This is just more of the rudeness.
But there is a grain of truth in there that a lot of updates require more work.
Being a single person development team I don't have much time to spare, and one thing that helps me spend time more efficiently is to stick with working on one primary development stream and not try to bounce back and forth so much to different releases.
In general for a release once it is wrapped up I'm then focused on moving on and working on the next version.
I will roll out an update if there is some major bug that really messes things up, for example this happened with v1 that a new Internet Explorer release caused v1 to not work, so I put out a 1.1 update to address that.
So there is a possibility of an update for fixing major problems but like I mentioned I put a lot of effort into a long beta period so that the final release is high quality and if all goes well with it then I'm on to the next version and that version is done. The betas of MoI are widely used by a large number of the user base so they get a lot more coverage than what they might typically get with other programs.
Your assertion that it's all only because of $$$ is both rude and incorrect.
  More Options
4649.24 In reply to 4649.21
Hi JDonner, you've said your final "bye" now a couple of times.
I will lock this thread now so that last one can actually be your final one.
Thanks for all your understanding about what small single person companies can do!
If you need all the trappings that go with a product from a big corporation that costs 10 times as much, then you're better off with that product and not MoI.
  More Options
Show messages:  1-8  9-24
