System Spec
All  1-3  4-9
4643.4 In reply to 4643.3
Hi Steve - actually that speaker model with all that woven mesh stuff in it is a pretty high complexity model that will tend to tax system resources.
A large number of skinny long tubes like that tend to be much heavier in NURBS geometry than in polygons.
Try turning off hidden lines display and bumping up the mesh angle to 25 or 30 degrees and uncheck "Add details to inflections". That will likely help somewhat - by default something that is tightly curved like those little tubes will get really a lot of polygons generated in the display mesh, the default settings are somewhat oriented towards making a nice smooth display but if you've got a heavy model the default settings can tend to generate an overly dense display mesh that bogs things down.
But that kind of dense number of tightly curved little tubes is actually getting into a quite high complexity level, that's not really a very good example of a "medium" complexity object.
> BTW can you suggest good training material/links to
> get you up to speed with MoI.
I'd recommend watching the video tutorials from the main documentation here:
http://moi3d.com/2.0/docs/tutorials.htm
Those go step by step building a few different simple models and generally explain the overall modeling approach.
Then there are additional tutorials linked to here:
http://moi3d.com/resources#Tutorials
But I'd recommend doing the above ones first.
4643.5 In reply to 4643.4
Thanks again Michael very helpful.
One more question if I may. I'm a beginner so bare with me :)
When I edit a imported model from MoI to C4D the model is very hard to edit as it has Ngons or very heavily triangulated depending of the MoI output setting (NGons or Tri/Quad). I suppose ideally it would be all quads :)
I have experimented with cutting a simple cylinder using curves and bevelling the edges. It comes into C4D with very nice edges made of quads but the sides of the cylinder constructed with heavy use of triangles
Is there settings I can play with change the behaviour of this or is it a matter of learning a practice/technique.
I chatted to some people and they have suggested in their workflow that they import models from moI but do not edited them directly once in C4D
Hope that makes sense
Steve
4643.6 In reply to 4643.5
I use C4D as well but never edit a model in C4D which I made with Moi3D. As said, Ngons are for me the best export option. C4D can handle this very good. For editing a model made with Moi3D, just use Moi3D instead of C4D.
Peace,
Rich_Art. ;-)
4643.7 In reply to 4643.5
Hi Steve - yes that's correct, typically you won't edit the polygon results that you export from MoI, once you export the model you can use it for rendering or uv mapping or stuff like that, but it's not particularly suitable for tweaking.
Re: All quads - the mesh generated from MoI is more oriented towards a light polygon count that is structured like the original NURBS topology which is a pretty different thing than generating all quads, see here for some previous discussion on that:
http://moi3d.com/forum/index.php?webtag=MOI&msg=4600.1
http://moi3d.com/forum/index.php?webtag=MOI&msg=3628.227
If you try to do stuff like bevel the exported mesh, you'll also mess up the stored vertex normals, C4D will have to calculate completely new vertex normals from the polygon data and that will tend to reduce the quality of the shading by quite a bit since automatically generated vertex normals don't really work that well on mechanical models where you've got things like large polygons next to small ones, auto normal generation tends to work better on organic models where you've got all more regularly sized polygons.
The vertex normals that MoI writes to the OBJ file come from the original NURBS surface so when they are used it helps to ensure that the polygons are shaded to look the same as the NURBS model, regardless of what kind of topology they happen to have. So you really don't want for those normals to get discarded, you get the highest quality shading and reflections when those original normals are used in the rendering. So that's another reason why you generally don't want to edit the mesh in some way that will cause vertex normals to have to be recalculated in C4D.
If you did want to edit the polygon results out of MoI, you would probably be looking at some process like using a retopologizing tool to lay quads down over the MoI-generated mesh to restructure it. There is a program called Topogun which is good for this, and also 3D-coat has a set of retopology tools for doing that kind of work as well. This is usually quite a bit of work though, so it's not really the main way of using MoI's output, it's more typical to just render the result from MoI.
4643.8 In reply to 4643.6
thanks Rich_Art
4643.9 In reply to 4643.7
Thanks Michael again, your a extremely helpful guy as mentioned on other sites
Now going to get stuck with MoI :)
Steve
Show messages: All  1-3  4-9
