System Spec
4643.1
I work mainly in Cinema4D and currently looking for a NURBS Modeller to add to my workflow.
There seems to be a good feedback concerning MIO so I'm trying out the trial version.
I'm Currently using my 3 year old dell laptop but it really it slows down if I do anything of reasonable complexity.
Can you tell a good realistic system spec for running MIO.
Is there any main issues I should aware of importing into C4D.
Many Thanks
Steve
4643.2 In reply to 4643.1
Hi Steve, really MoI has pretty minimal system specs, it should run fine on a 3 year old laptop.
Have you possibly adjusted some of the settings in MoI? There is an option in MoI under Options > View > Meshing parameters - make sure you have not set the value for "Mesh angle" to be lower than 10 degrees.
You can also try increasing the value to 25 degrees and uncheck the "Add details to inflections" checkbox to make display meshes be a bit coarser but there will also be a speed increase that goes along with that.
Also turning off hidden line display can speed things up as well.
But in general I'd normally expect for a 3 year old laptop to be able to run things fine, what size of file are you working with that you consider reasonable complexity?
Transfer from MoI to Cinema4D usually goes quite smoothly.
You should use OBJ format for the transfer and you can use n-gons if you want, C4D seems to handle n-gons quite well.
Make sure you have not disabled vertex normals importing, it's important to have vertex normals transfer over to get nice quality smooth shading.
You may want to set a scale factor for the export from MoI under Options > Import/Export > OBJ options - one little quirk is that the import into C4D seems to come in at a somewhat smaller size than things are usually constructed at in C4D so to make a better match for the default render settings in C4D for stuff like bias factors and whatnot you may want to set a scale factor of 100 or something.
Then the only other thing that I can think of is that if you want to have colors preserved from styles that you have assigned in MoI you need to get the Riptide OBJ I/O plug-in on the C4D side to handle the OBJ import to preserve those, the only problem with Cinema's default OBJ importer is that it does not read in the material information.
But for the most part there is usually not a lot to worry about with transfers into Cinema4D using OBJ format.
4643.3 In reply to 4643.2
THanks for the reply Michael,
Here's the file (speaker) I loaded
http://moi3d.com/forum/messages.php?webtag=MOI&msg=4561.17
As I said my laptop struggles, even trying to move it.
My setting are the default settings so my mesh angle is set to 10. I will try other options you mentioned
BTW can you suggest good training material/links to get you up to speed with MoI.
I tried vimeo but videos have no audio etc
Many Thanks
Steve
4643.4 In reply to 4643.3
Hi Steve - actually that speaker model with all that woven mesh stuff in it is a pretty high complexity model that will tend to tax system resources.
A large number of skinny long tubes like that tend to be much heavier in NURBS geometry than in polygons.
Try turning off hidden lines display and bumping up the mesh angle to 25 or 30 degrees and uncheck "Add details to inflections". That will likely help somewhat - by default something that is tightly curved like those little tubes will get really a lot of polygons generated in the display mesh, the default settings are somewhat oriented towards making a nice smooth display but if you've got a heavy model the default settings can tend to generate an overly dense display mesh that bogs things down.
But that kind of dense number of tightly curved little tubes is actually getting into a quite high complexity level, that's not really a very good example of a "medium" complexity object.
I'd recommend watching the video tutorials from the main documentation here:
http://moi3d.com/2.0/docs/tutorials.htm
Those go step by step building a few different simple models and generally explain the overall modeling approach.
Then there are additional tutorials linked to here:
http://moi3d.com/resources#Tutorials
But I'd recommend doing the above ones first.
4643.5 In reply to 4643.4
Thanks again Michael very helpful.
One more question if I may. I'm a beginner so bare with me :)
When I edit a imported model from MoI to C4D the model is very hard to edit as it has Ngons or very heavily triangulated depending of the MoI output setting (NGons or Tri/Quad). I suppose ideally it would be all quads :)
I have experimented with cutting a simple cylinder using curves and bevelling the edges. It comes into C4D with very nice edges made of quads but the sides of the cylinder constructed with heavy use of triangles
Is there settings I can play with change the behaviour of this or is it a matter of learning a practice/technique.
I chatted to some people and they have suggested in their workflow that they import models from moI but do not edited them directly once in C4D
Hope that makes sense
Steve
4643.6 In reply to 4643.5
I use C4D as well but never edit a model in C4D which I made with Moi3D. As said, Ngons are for me the best export option. C4D can handle this very good. For editing a model made with Moi3D, just use Moi3D instead of C4D.
Peace,
Rich_Art. ;-)
4643.7 In reply to 4643.5
Hi Steve - yes that's correct, typically you won't edit the polygon results that you export from MoI, once you export the model you can use it for rendering or uv mapping or stuff like that, but it's not particularly suitable for tweaking.
Re: All quads - the mesh generated from MoI is more oriented towards a light polygon count that is structured like the original NURBS topology which is a pretty different thing than generating all quads, see here for some previous discussion on that:
http://moi3d.com/forum/index.php?webtag=MOI&msg=4600.1
http://moi3d.com/forum/index.php?webtag=MOI&msg=3628.227
If you try to do stuff like bevel the exported mesh, you'll also mess up the stored vertex normals, C4D will have to calculate completely new vertex normals from the polygon data and that will tend to reduce the quality of the shading by quite a bit since automatically generated vertex normals don't really work that well on mechanical models where you've got things like large polygons next to small ones, auto normal generation tends to work better on organic models where you've got all more regularly sized polygons.
The vertex normals that MoI writes to the OBJ file come from the original NURBS surface so when they are used it helps to ensure that the polygons are shaded to look the same as the NURBS model, regardless of what kind of topology they happen to have. So you really don't want for those normals to get discarded, you get the highest quality shading and reflections when those original normals are used in the rendering. So that's another reason why you generally don't want to edit the mesh in some way that will cause vertex normals to have to be recalculated in C4D.
If you did want to edit the polygon results out of MoI, you would probably be looking at some process like using a retopologizing tool to lay quads down over the MoI-generated mesh to restructure it. There is a program called Topogun which is good for this, and also 3D-coat has a set of retopology tools for doing that kind of work as well. This is usually quite a bit of work though, so it's not really the main way of using MoI's output, it's more typical to just render the result from MoI.
4643.8 In reply to 4643.6
thanks Rich_Art
4643.9 In reply to 4643.7
Thanks Michael again, your a extremely helpful guy as mentioned on other sites
Now going to get stuck with MoI :)
Steve
