Water flow through pipe animation
4628.1
Hi,,,,
I want to create animation of water flowing through pipe. Any body have experience which software I can use as companion to MoI ?
Thank you...
4628.2 In reply to 4628.1
4628.3 In reply to 4628.2
Looks like Blender is a good choice, I will take a look at the animation tutorial.
Do you think Modo is another water flow animation software that I can consider ?
Thank you
4628.4
Modo doesn't have fluid dynamics.
RealFlow is one program for this sort of thing.
4628.5
Hello,
If it is not for commercial use you might check out Houdini Apprentice HD for $99 plus a learning curve.
4628.6
It really depends on how complicated your animation needs to be. You may not need physics simulations at all depending on what you're doing. In that case an easy to use and affordable program like Carrara might do the trick.
