Screw Thread Tutorial Online
 1  2-21  22-41  42-51
4623.2 In reply to 4623.1
Hi OSTexo,
No Critiques. Very nice.
A comment could be that ShrinkTrimmedSrf can be immediately run on your solid. No need to seperate and rejoin.
Thanks, Burr
4623.3
Hello Burrman,
I didn't know that, it will go into the next tutorial. Do I just run Alt+S after selecting the solid? Thanks.
4623.4 In reply to 4623.1
That's awesome OSTexo, thanks very much for producing this!
I added a link to it from the MoI resources wiki page as well.
4623.5 In reply to 4623.3
"""""" Do I just run Alt+S after selecting the solid? """"""""""
Yes thats it...
Thanks again....
4623.6
Hello,
Thanks for the info, that will save me some time. The video took me a little longer than expected since I didn't use any templates and built everything up from scratch including the sound effects, and I'm by no means a pro when it comes to After Effects and Premiere Pro.
4623.7 In reply to 4623.1
Very detailed conception
my suggestion : the video must be not longer than 12 - 15 minutes maxi
over this time attention is flying away :)
4623.8
Hello, Frenchy Pilou,
I agree, I might break up the tutorials more in the future. Also remember is am a relative amateur with MoI so it takes me at least twice as long to accomplish tasks, and speaking about them slows things down, but I think talking about the procedures helps with the learning curve. Perhaps break down into curves and then solids modeling?
4623.9
Thank you very much OSTexo! Your long spent time formulating this tutorial was very worth the wait.
I feel like I just completed a trek to the guru on the top of the mountain. :-)
That was extremely informative and drawn out on a good pace so that most folks could see what happens between point A and point B.
I encourage your future tutorial endeavors.
BTW, do you have a link to a site or official chart for specs on those standard spacings, pitches and angles you were referencing?
4623.10
Hello,
This is the link I worked from. I am coming to think threading is all about tolerances, so rather than be confused by all the numbers on various manufacturer sites I used this for the reference. Assuming you're using UTS or ISO Metric threads, which is most of the world apparently, you can make any of those screws just knowing the pitch. I really hope my interpretation of this diagram is correct. If not please let me know.
http://en.wikipedia.org/wiki/File:ISO_and_UTS_Thread_Dimensions.svg
http://en.wikipedia.org/wiki/Unified_Thread_Standard
http://en.wikipedia.org/wiki/ISO_metric_screw_thread
4623.11 In reply to 4623.10
Hootchie-Mama!
Thanks OSTexo.
BTW: Look what I found: http://www.earnestmachine.com/Images/PDF/training.pdf
4623.12
Hello,
Thanks for the thanks, do I hear rumblings of perhaps trying a Twist command screw thread?
4623.13 In reply to 4623.12
Tried that a little. The Twist command seems to add a graceful swoop to the faces of anything twisted - as the logic of that mechanism dictates...
Sweeping a profile on a helix is the supreme way to make threads so far.
4623.14
Hello,
Great reference, thanks. Using this information could a partial thread calculation be made to determine the tapered helix parameters and to accurately place the secondary helix on the bolt cylinder? I know that NSF type stuff specifies this as 3/4" rise per 12" taper, so it's easy to know exactly where the threads are going to leave off cutting the cylinder, but I can't seem to find out the parameters from UTS or ISO Metric. I also can't find the depth of those arcs at the crest and root of the thread, do you have a reference on how to calculate that? Thanks.
4623.15 In reply to 4623.14
Very well done OSTexo!! :)
Thanks!!
4623.16 In reply to 4623.13
Hi Mike,
Only when "Limit to axis" is checked - that acceleration swoop is what makes it possible to twist only a limited section of an object and not have any odd hiccup where it transitions into the non-twisted part.
If you turn off "Limit to axis", then Twist will generate a totally regular helix effect, and actually any lines parallel to the twist axis will become a regular helix in shape.
So it could be a good fit for threads - definitely worth a try!
A little while ago I had thought that Twist wouldn't really work so well for this kind of thing where you'll probably be doing quite a lot of turns, but it actually seems to handle it quite well. By the way, you can type in stuff like 5*360 for doing 5 full turns for the twist angle.
4623.17
RE: Threads,
The new Twist command is pretty cool for doing quick metal screws.
Instructions included in the 3dm file.
4623.18
Hello,
Thanks for the addition to the wiki Michael and for the compliment, I really appreciate it. I think there probably is a way to make a screw thread very quickly with the Twist command, but I'm letting the smoke out of my brain trying to think of how to get a flat flank to the screw thread.
4623.19 In reply to 4623.18
Thanks for all the info/tutorials guys. Much appreciated..
Peace,
Rich_Art. ;-)
| C4DLounge.eu | Our Dutch/Belgium C4D forum. Cinema4D R13 Studio + VrayForC4D + UVLayout Pro + 3DCoat
4623.20 In reply to 4623.8
Hi OSTexo,
""""""""""""""""I agree, I might break up the tutorials more in the future. Also remember is am a relative amateur with MoI so it takes me at least twice as long to accomplish tasks, and speaking about them slows things down, but I think talking about the procedures helps with the learning curve. """""""""""""
I think your tute was well paced and thought out. I think it is easy to follow and grasp. Commonly, tutes are done by experts who know all the nuances and tricks/ins and outs and "Baffle" newer users with whats going on.. Old hands may get impatient, but targeting the old hands may make a lessor, or typical tutorial. Congratulations!
4623.21 In reply to 4623.1
Hi OSTexo,
excellent tuto! Nothing to add above what was already said.
I noticed a couple of things you did and I wonder why those are necessary?
1- You rotated your base screw cylinder, I think you said something about the seam but I still wonder why this operation is necessary?
2- You shrink things a couple of time also, I'd also like to know why this is necessary or useful?
Felix
PS. If you think you're a newbie, I wonder where that puts me...
Show messages:  1  2-21  22-41  42-51
