Hi Juan, there isn't any wireframe method currently.
One thing you can do is turn down the mesh density - to do this go to Options and set the Meshing parameters Surface angle and Trim curve angle to 20 or 30 - this will produce a rougher mesh but will be faster. You can also turn off hidden-line curves and edges to gain some speed as well.
The default mesh density is set to be pretty detailed to provide a smooth-looking display. But if you have a complex model that can add up to a lot of polygons so turning down the density can help with that.
