New Twist command coming
 1-6  7-26  27-46  47-66  67-68
4614.7 In reply to 4614.1
looks pretty impressive, I'm it will find many usages and users.
Felix
4614.8 In reply to 4614.7
After Twist, that was Jerk, no? It's Rock'n Roll!
Step by step, I find again the functions that I liked in Amapi 3D.
It goes to miss some functions to create skins with a lot of irregularities; and why not, commands of erosion & corrosion (I don't know if it's possible with NURBS).
I would like always, a nice choice of bevels on letters (LOL!).
Have a good day.
4614.9
This is awesome news Michael - I can't wait to try this out.
Just last night at the store I took a look at some of the new P&G fabric softener bottles:
http://www.packagingnews.co.uk/design/world-design-procter-gamble-fabric-softener/
http://popsop.com/2651
There seemed to be four or five brand names with the same bottle. I was wondering if this shape was formed by Sub-D or maybe by a hand-carved clay sculpture by industry artisans.
I'm not sure that a twist deformation of the nature that you are presenting was what formed this bottle, but I find it interesting that it gave me pause to consider last night.
Would you consider any sub-control elements such as a positional start and end to the twist deformations (perhaps defined by the inference on where the start and end twist-axis definition is made)?
And also, perhaps a logarithmic or varied control over the angular degree through the body of the twist - where an object set could start slowly on the twist, then accelerate to a more acute twist?
But none the less, this is great news! And it looks so smooth too. This will surely streamline a lot of procedural work in things like turbine blades and ornamental decoration.
4614.10 In reply to 4614.9
Looks great Michael.
Any chance to have an easy in/easy out option ?
EDITED: 3 Dec 2015 by PAQ
4614.11 In reply to 4614.8
Hi Bard,
NURBS by themselves are not very well suited for that - mostly because a NURBS surface is made up of a rectangular grid of points, so to add a little divot in one area of a NURBS surface you actually have to add in an entire row or column of control points. Polygon or sub-d methods tends to be better for adding that type of detail because they can add more polygon faces in a small localized area.
Also corrsion or weathering is often added using displacement texture mapping or rendering shaders rather than explicit modeling of the weathering itself.
If you do want to model corrosion or little bumps and stuff like that, one of the brush-based sculpting programs like ZBrush or 3D-Coat are better suited for that kind of stuff rather than trying to do it with NURBS. NURBS modeling can work well for building the kind of ideal smooth starting surface though.
4614.12 In reply to 4614.9
Hi Mike,
Hard to say for sure, but I wouldn't be surprised if it was actually done with NURBS modeling anyway, despite it being something that's easier to do with Sub-d. That's just because for a pretty long time stuff across a wide range of manufacturing industries have been done with NURBS. Sub-d modeling in manufacturing is relatively new.
At the moment it does stop at the bottom of the twist axis - anything below the bottom axis point does not get affected. But this is actually kind of problematic because the deformation mechanism doesn't really work that great with abrupt changes, it kind of messes up the fitting mechanism and causes a little hiccup right in that area.
So making the twist be limited to a certain zone would probably have to be combined with some kind of "ease-in/ease-out" method as well so there wasn't an abrupt transition from the area of no twist into the area of twist happening.
That might be possible, but it would be good to avoid controls for it that make you feel like you're taking a math quiz...
So far I haven't really thought about how to control something like that.
4614.13 In reply to 4614.10
Hi PaQ,
Maybe - do you maybe have any good description available for what those In and Out parameters that you're showing there actually do?
Is that something related to some animation controls used in various other places in Modo?
4614.14 In reply to 4614.12
Thanks Michael,
C'mon... couldn't you just imagine the suave look of a nifty scientific graphing calculator widget in MoI's side pane? ;-) I think that was a nightmare I had the other night.
I could imagine a check box in the dialog box like the one on the Spiral command, where if you check it you could then pick a twist angle at one end and then at the other.
As for an ease in / ease out control - If you could imagine a simple button in the dialog that says [with ease] that would add a spacing entry in the dialog, not unlike the one for the Fillet tool.
You could then ask for a numeric range by which to go from 0 to 88 mph in 6 seconds, so to speak, defining a soft transition on the ends - if the twist ends are inside an object's length.
For example: I could select an object, pick a start and end point, choose the rotation angle factor for one point and then the other, then specify the soft ease transition distance...
No, no... to much.... my ego would get drunk with power... ;-)
(simplicity)
Don't mind my creative rambling Michael, I'm still marveling at the twist tool's amazing potential.
4614.15 In reply to 4614.14
Hi Mike,
> at the other.
I don't think that will work though - in the spiral command you're picking 2 different radius values - in the twist command you don't pick any radius values at all, because the distance of the particular point being deformed away from the axis is actually used as the radius of the helix.
Since it is a deformation that is being applied to objects, it's a bit of a different thing than drawing a single curve like the spiral.
Right now I can't see how 2 different twist angle would work - I mean the way twist works is that at the base of the twist axis you get 0 rotation there and it goes up to the full angle at the top. To do "ease in/ease out" doesn't really mean to change the start or end angle so much as it would mean changing how the transition between them would work...
Controlling the transition speed is not really the same thing as specifying 2 different angles...
4614.16 In reply to 4614.14
I would imagine it as having the center axis pole (Like when creating a helix) with a point that slides up and down the pole (Like the loft seam point alignment points). The sliding point would define a percentage of the angle at the placed point.
4614.17 In reply to 4614.16
Hi Burr,
Not sure that would work, because that's would be some kind of linear step that would probably not provide for a smooth gradual start or end.
Something that does "ease-in/ease-out" probably needs to be based on more like some kind of cubic blend that would start with only a little bit of "angular velocity" at the ends, and do more near the middle.
4614.18 In reply to 4614.17
A "bulge slider" for twist..... (well, 2. One for in and one for out)
4614.19 In reply to 4614.18
Hi Burr,
Maybe - if I can figure out a some kind of setup that has a scale factor in it that can be applied to it...
But I'm not sure yet how that would work.
4614.20 In reply to 4614.18
Hi Burr,
> in and one for out)
The other problem with this is that it would probably mean adding in an extra step to the entire Twist command flow just so you could possibly tweak this value.
Right now the way it goes is you enter in a twist angle and once you do that you're all finished...
It doesn't seem very good to add in an entire extra stage just for twist acceleration tweaking.
I think it will be possible to add an option though to limit the twist to only happen inside of the axis range and when you do that there will be an automatic gradual ease-in/ease-out built in, here's an example twisting just the upper half of this thing:
Or here with twisting only the middle area:
That will allow for things like this - limited range twist with a twist axis between these 2 points:
4614.21 In reply to 4614.10
Hi PaQ, you were showing the Modo twist function with this screenshot:
But really that's a pretty good example of a fairly prodigious onslaught of parameters.
It's a pretty big goal for MoI's UI overall to avoid that kind of huge control panel - that seems to have something like 21 controls in it?
That certainly does give a lot of flexibility but it really leaves behind the overall "easy to use" aspect by quite a bit.
One thing that helps avoid that "all at once" type presentation in MoI is that stuff is broken down in stages, like the start and end axis are 2 different stages of the Twist command and once you finish those stages those pieces are done and don't have to see anything about them after that.
Sometimes then at the end of some commands there may be an "Adjust options" stage, but it can be kind of awkward to add in a separate options tweaking stage all the time for every single command, especially if the options are kind of hard to understand... That seems to me to be where having some ease-in/ease-out adjustment tools would kind of fall.
4614.22
Can't wait for this Michael G! Looks great!
Michael T.
4614.23 In reply to 4614.21
Hello Michael,
flow and twist are pretty awesome!
For Controlling the twist why not use additional evaluating lines like the scaling rail in the sweep command. Just with 2 lines the first representing the length of the twist axis and evaluating the distance to the points of the second line get the amount of twisting. The farest point is used as 100%, touching the first line is 0%. Going to the opposite site reverses twisting :-)
Michael
< limited range twist
Very cool idea!
4614.25 In reply to 4614.20
That look awesome Michael ! Can't wait to try it out :)
4614.26 In reply to 4614.11
Hello Michael,
<< ... NURBS modeling can work well for building the kind of ideal smooth starting surface though.>>
Yes! So, is that will be possible to imagine a function to liquefied an objet; by example, a full cube (an ice cube) or one part of a cubic shape, may be on a plane or on others curves? As if, this objet flowed or melted, like water or oil? A thing to make drops or tears, to give the look of something watery. A sort of smooth-function (to apply a gravity force; a pression; a "fluidic" deformation on a objet)???
Hum?... I drop smooth effects dreams (I'm not technician).
I know well Amorphium (the first version of Coat3D), I have made a lot of sculptures with it (many Menhirs & Cromlechs too) it's very good to simulate all sort of old stones, very eroded; and full crazy things, as we can see now... It's a very good software for the Artists.
I asked me also, if the METABALLS function was specific to polygons applications, or if we could to make a such effect with NURBS?
Thank you.
Show messages:  1-6  7-26  27-46  47-66  67-68
