Can't fillet this curve
All  1-6  7
46.7 In reply to 46.6
Yes, on second thought that doubleclick to reset all could cause problems. It's easy to doubleclick by mistake with a tablet pen and that would be frustrating if all viewports are reset.
Another suggestion for a really practical feature I use all the time modeling in XSI. It's called Isolate Selection and it lets you temporarily isolate the currently selected objects so they are the only ones shown in the viewports. Often with more complex objects consisting of several parts, some parts get in the way when you want to examine a particular piece. This option lets me do it very quickly, without having to mess with turning on/off a bunch of layers (although layers still have their place ofcourse). When you want to show all objects again, you just select Isolate All (which should really be called Isolate None I guess).
Center view on current selection would also be nice.
I'm having another problem with geometry, boolean this time. Trying to boolean the wheelhub with this cylinder. The result is instead a trim, just the top surface is trimmed, but there are no walls or bottom. I tried doing it in Rhino and it works ok (btw those small fillets for the holes were made in Rhino also, wasn't possible in MoI).
I attached the new model.
Show messages: All  1-6  7
