Ta daaa :)
Some observations/opinions so far:
The fillet curves didn't work at first because I didn't realize the first curves (belonging to the object) where still selected, after I copy-pasted. Usually when you copy-paste an object, the original object becomes deselected, it works like this in every modeling program I know. But with Moi working differently (multi select is on by default) it's something to get used to. I think many users that don't use a tablet (and perhaps even those who do) will find it difficult at first. Perhaps a future option of normal Shift select for mouse users would be good.
A small notice of what/how many objects are currently selected.
Doubleclick on the Reset button in viewport could reset all viewports.
I noticed when selecting faces of an already selected object, it's very difficult to see the tone change between yellow and slightly darker yellow. I think this will get difficult with more complex objects. Ability to customize the colors would be useful.
The panel Construct/Transform. I find myself often needing to switch between the two. A separation of these two panels would improve workflow. I imagine you will have to add other panels in the future, in that case the Construct can share a panel with other tools used less often and the same for the Transform panel.
The viewports are very smooth and the models are displayed without gaps, antialiased lines, very nice! I looked at Rhino also and it's display seems much rougher and more "chaotic". I know one can set the quality of the display to eliminate gaps but that slows it down.
Also, zero crashes so far :) Now I'm going to try my luck modeling a mouse.....the mousepad should be easy.
