demo import
4590.1
Hello,
I'm about as new as one can be, at least to Moi. Using the 30 day demo version, I wanted to test the 'import' of a file. This file was saved in .3dm format (v4 from rhino). Nothing blew up but nothing imported. I tried using .step and .stl; nothing worked. Is file import disabled in the demo version? If it is, it should be grayed out.
4590.2 In reply to 4590.1
Hi rd - the 30-day trial does not have file imports disabled.
However, there are a lot of different kinds of things that Rhino can save to 3DM files, and MoI only reads in some kinds of entities from the file.
Things like spotlights, dimensions and polygon mesh objects are not things that MoI deals with directly so those kinds of entities will not show up if they were in the 3DM file that you were trying to load.
Another one is block instances, those are also skipped.
From inside Rhino try using the "What" command to see what kind of object you are trying to work with.
If it's a block instance use the Explode command in Rhino to change it into regular geometry.
If it's a mesh object, then that's not the right kind of data that MoI can import - MoI works only on NURBS data and not on polygon mesh data.
4590.3 In reply to 4590.1
Hi rd, also you mentioned:
These are very different file formats - STEP is meant to contain NURBS data and if you try to export polygon mesh data out from Rhino into STEP format you will get an empty file since the STEP format is not intended to contain that kind of model data.
STL on the other hand only contains polygon mesh data - so you can export a polygon mesh file out from Rhino with that, but you cannot read an STL file into MoI since MoI only imports NURBS data and not polygonal type model data. MoI can generate an STL file at export time at which point it will break NURBS surfaces up into little triangle facets, but it won't read that kind of data into MoI to work with at model time - MoI only works with NURBS surface/solid data at modeling time.
4590.4 In reply to 4590.3
Michael, thanks for the info. Have you heard of or had any experience getting nurbs data from Form-Z?
4590.5 In reply to 4590.4
Hi rd,
> data from Form-Z?
The situation in Form-Z is kind of similar - some types of objects in Form-Z are made up of polygonal data and there are other types of objects that are made up of NURBS data.
It shouldn't be a problem to transfer NURBS object data from Form-Z into MoI, use any of these NURBS capable formats to do that: 3DM, STEP, IGES, or SAT.
But if your objects in Form-Z are made up of polygonal data, then that will be more difficult to get into MoI because again that's a much different kind of 3D model data than what MoI is designed to work on.
