Fillet won't fillet at half radius
All  1-5  6-8
4584.6 In reply to 4584.1
Hi NightCabbage, also you may already know this but just in case - you don't actually need to do a separate on the rectangle first, you can select the whole still joined rectangle and then do a Fillet and it will prompt you to pick which corners you want to fillet.
4584.7
lol This all sounds awesome :)
I think the problem is that, to my knowledge, these features aren't documented?
I bet there are ton of features in MoI that would make my life much easier - but I just don't know they exist! :D
4584.8 In reply to 4584.7
Hi NightCabbage,
Being able to fillet corners of a single joined curve is documented in the help file under Fillet:
http://moi3d.com/2.0/docs/moi_command_reference7.htm#fillet
"Selecting a single curve that has corners in it (for example, a rectangle curve) will allow filleting of some or all of those corners."
Also one of the example images shows that kind of filleting with selecting corner vertices...
Show messages: All  1-5  6-8
