Flow problems.. Bad filleting
All  1  2-9
4569.2 In reply to 4569.1
Hi Rich_Art, looks most likely to be a problem with Flow - that kind of display thing will happen if there is a problem in the trimming boundaries. Maybe something along the lines of not quite enough accuracy in the deformed edges. It will take some detailed investigation to figure it out.
Can you post or send to me a version of the file _before_ doing the flow but with it all set up to do it? If I can repeat the flow over here and repeat the problem then that will give me something to work with for testing a fix for it as well.
4569.3 In reply to 4569.2
Aha ok..
Here is a simple setup similar I used. After the flow command I used the array to make 4 copies in a circle.
Peace,
Rich_Art. ;-)
| C4DLounge.eu | Our Dutch/Belgium C4D forum. Cinema4D R13 Studio + VrayForC4D + UVLayout Pro + 3DCoat
4569.4 In reply to 4569.3
Mmmm I just redid the flow on the sphere and array 5 copies. I can't reproduce the bad filleting. The objects seems to be ok now.
Peace,
Rich_Art. ;-)
4569.5 In reply to 4569.4
OK Looks like the problems are gone.
See example image.
Peace,
Rich_Art. ;-)
4569.6 In reply to 4569.5
Hi Rich_Art, I'm glad that it's working for you ok now!
But on the other hand it will be difficult to figure out what was going on with the original bug without being able to reproduce the problem...
Please let me know if you run into something like that again.
4569.7 In reply to 4569.5
Wow!! That image would be to difficult to distinguish from real or render ;)
And that's C4D? Can't remember being that impressed from even a 3DS Max render.
4569.8 In reply to 4569.7
Thanks. I'll report any strange thing immediately..
@FlashFire,
Thanks...
See image on the links underneath. C4D & Vray are the perfect combo for use with Moi3d.
http://moi3d.com/gallery/viewitem.php?id=412
http://moi3d.com/forum/messages.php?webtag=MOI&msg=4571.1 scroll down for the final image.
Peace,
Rich_Art. ;-)
cool result!
Show messages: All  1  2-9
