> The z scale factor, 0.125 is rounded up by MoI to 0.13 ?
Rounded up where? I mean which part of the UI are you looking at?
Most numeric values in the UI are shown to 2 decimal points, you can adjust that under Options > General > Decimal display. The default is 2 decimal places but you can adjust it to higher if you want.
In the future I'm probably going to adjust edit fields to remember if you typed in a number with more decimal places than that in a previous run of the same command and show the same thing you typed in when you start up that command again, but right now in that kind of a situation it just uses the regular decimal point display setting for how many places to display to.
Thank you Michael, for explaining that.
So I incorrectly assumed it was rounded, upon seeing 0.13 in the corner display, instead of 0.125.
The value is still 0.125 then.
I also subsequently typed in 0.125 in the corner display, which soon switched to showing 0.13. :)
