How to punch a closed hole
All  1-3  4-7
4564.4 In reply to 4564.1
Hi Rich_Art, also looking at your shape you've got another problem which is that the little piece that you're trying to union on is just a single surface with no thickness to it at all - that won't be possible to union on to the hole because it won't make a proper solid since there would be no thickness to the object at all in that spot.
In order to make a proper object there you would need to extrude that little piece you're trying to union to have some thickness before it would be able to be unioned on to the other solid and make a proper solid result.
Really for a case like this instead of cutting a hole and then partially filling it in with another piece it's probably best to initially cut it with an extruded cutting object using boolean difference with the cutting object not going all the way through, so it's all done after the first boolean.
4564.5 In reply to 4564.1
Probably you didn't want to really have that little tiny disc hole at the inside tip of the rounded shape - that looks like it was probably caused by doing a revolve with one end of the revolve profile not quite touching the axis.
4564.6 In reply to 4564.3
Wow.. First a big applause for your outstanding support. Don't forget you must sleep sometime as well. :-)
Thanks for the explanation. This makes perfectly sense. I'll redo the body and make sure it is a solid.
Peace,
Rich_Art. ;-)
| C4DLounge.eu | Our Dutch/Belgium C4D forum. Cinema4D R13 Studio + VrayForC4D + UVLayout Pro + 3DCoat
4564.7 In reply to 4564.6
Thanks again Michael.
I remodeled the body and the glass. It's much better now.
Peace,
Rich_Art. ;-)
Show messages: All  1-3  4-7
