Round Hole...
All  1-7  8-10
4557.8 In reply to 4557.7
> Danny, to address that I've thought about adding
> an option to limit the cutting depth when using
> curves as cutting objects in boolean difference.
That'll work :) and as a special addition to us MCAD guy's you're going to have an option to put a 118 deg conical drill point on the end of that......you are thinking about it aren't you? ;)
4557.9 In reply to 4557.8
Hi Danny, not really sure yet if something like that would be part of the booleans or if that level would be some special hole command.
But a depth limit for booleans with cutting curves would be a good step anyway! :)
4557.10 In reply to 4557.9
Maybe with 2 forms of curves? same size or not for the internal form
circle - circle
circle - close curve
Close curve - close curve
Show messages: All  1-7  8-10
