Round Hole...
All  1-3  4-10
4557.4 In reply to 4557.3
Hi Riko - but all you have to do currently is draw a circle and do boolean difference.
That's not very many steps already...
What kind of steps were you thinking of instead?
If you're placing holes in a repeated pattern drawing just one circle then allows you to use the array commands to replicate the circle into a pattern and then you can do just one boolean difference using all those replicated circles as the cutting objects.
Is it that you are always using a circle of a specific radius?
If that's the case then maybe the QuickCircle script would help, see here:
http://kyticka.webzdarma.cz/3d/moi/#QuickCircle
4557.5 In reply to 4557.4
Thanks Michael! I am understanding. Ok.
-Riko
EDITED: 28 Sep 2011 by RIKO
4557.6 In reply to 4557.4
In relation to Riko's request the issue arises, for me anyway, when doing several blind holes.
I think I've asked the same question once before, it's a MCAD thing :)
4557.7 In reply to 4557.6
re: Blind holes - Riko is that the issue, that you don't want a hole that goes all the way through the object?
Danny, to address that I've thought about adding an option to limit the cutting depth when using curves as cutting objects in boolean difference.
4557.8 In reply to 4557.7
That'll work :) and as a special addition to us MCAD guy's you're going to have an option to put a 118 deg conical drill point on the end of that......you are thinking about it aren't you? ;)
4557.9 In reply to 4557.8
Hi Danny, not really sure yet if something like that would be part of the booleans or if that level would be some special hole command.
But a depth limit for booleans with cutting curves would be a good step anyway! :)
4557.10 In reply to 4557.9
Maybe with 2 forms of curves? same size or not for the internal form
circle - circle
circle - close curve
Close curve - close curve
Show messages: All  1-3  4-10
