Question re constraining two curves
 1-19  20-25
4555.20 In reply to 4555.19
Hi Marc,
> I was thinking about this and it could be cool to have
> these interactive points in 2d fillet also.
Unfortunately that's probably pretty difficult - curve fillet currently works by calculating the result from 2 curves and a radius value. Trying to drag one point to manipulate the curve fillet would probably involve some kind of reverse calculation from that which would involve writing a completely new solver.
4555.21 In reply to 4555.20
Maybe a center radius point that could be draggable?
The vector scribe plugin for illustrator does something like this:
http://www.youtube.com/watch?v=uZHtamBiBHo
Marc
4555.22 In reply to 4555.21
Hi Marc,
Right, but that's the one that requires a different solver.
Instead of solving the problem "find the points on the 2 curves to make a fillet arc of the given radius", it's more like "find the points on the 2 curves to make a fillet arc with the center closest to the given center point, with radius being calculated".
It's a different problem to solve and would require a different solver mechanism to be written to calculate it - that's certainly possible but it's a fair amount of work to do it. So that could be possible in the future.
4555.23 In reply to 4555.22
Oh, I think I understand, but then again I have a bad cold. :-)
I guess It's a kind of mechanism that looks simple but takes a lot of work to implement.
Marc
4555.24 In reply to 4555.23
Hi Marc, well it kind of depends on what you mean by "a lot" ... :)
It's probably a couple of days worth of focused work, but that kind of puts it into a category of stuff that becomes more difficult to schedule.
It's something that's simple if you only have a fillet between 2 line segments of course, but with 2 arbitrary wiggly curves rather than just lines it's a much different scenario to deal with.
It's a good idea though and I'd like to work on it at some point, it's just difficult to know when.
4555.25 In reply to 4555.24
It looks to me more like a slider for the radius of the fillet.
Show messages:  1-19  20-25
