How to make this indent
All  1-6  7-13
4548.7 In reply to 4548.6
Ok next problem.
I try to boolean this to 1 object but it keeps calculating after 15min I did stop the calculation.
any Idea??
Peace,
Rich_Art. ;)
| C4DLounge.eu | Our Dutch/Belgium C4D forum. Cinema4D R13 Studio + VrayForC4D + UVLayout Pro + 3DCoat
4548.8 In reply to 4548.7
Ok 'with out the filleting etc it looks not bad at all. I'll keep it as it is. Time for a new doodle.
Peace,
Rich_Art. ;)
4548.9 In reply to 4548.7
Hi Rich_Art,
> any Idea??
If I delete one of the outer surfaces, you can see that the inside of the pieces you are trying to boolean have a kind of barely skimming overlapping surface area:
Those kinds of barely skimming overlaps between the pieces being booleaned can add a lot of complexity to the boolean calculation, because the boolean code is going to try and intersect those 2 barely skimming surfaces together, and if one is just bumping up and down through the other one by a tiny amount that can make for a whole lot of complex intersection curves between those objects.
So just in general surface overlap like that is a much more difficult boolean to handle. If you want to boolean together 2 pieces like that, it's better to create the indented piece to be sunken down a little bit into the other object, sort of pushing through it by a small distance instead of having 2 surfaces just barely skimming along each other.
4548.10 In reply to 4548.9
Thanks Michael. That makes sense indeed. It is just with regular 3D Apps. 2 polygons occupying the same space is a no go.
I'll adapt the thickness of the object and try the boolean again.
Peace,
Rich_Art. ;-)
4548.11
Nice use of the Flow tool Rich_Art!
4548.12 In reply to 4548.11
Thanks Magic..
@Michael,
It worked good....I even managed to add a little bevel. Took some calculation time but that is ok.
See image. Now back to C4D and render out an image again. :-)
Peace,
Rich_Art. ;-)
4548.13
A more traditional way of making a nurbs object like this is to create only one segment. Then circular array it. Join them all together.
Show messages: All  1-6  7-13
