Align along a direction
All  1-2  3-4
4545.3 In reply to 4545.2
yes when you want align some points of a curve
thinking also to an "inclined" Edit Frame
but one more time CPlane Resovle this case :)
4545.4 In reply to 4545.3
Yeah for aligning full objects it won't quite work because for entire objects the various options for top / bottom / horizontal center / vertical center / etc require a full 2D coordinate system (both a horizontal and vertical direction defined) in order to make sense, and just snapping on to a single line would not really well define a full 2D coordinate system, like for example would that line be the x axis of the coordinate system or the y axis of it?
But when aligning only a set of control points it could be possible to make the options different than when aligning full objects, something more like Horizontal / Vertical / Closest point.
Yes, setting the cplane controls the orientation of the edit frame.
Basically if you want to work at a particular angle instead of the default world axis directions then setting the cplane to that angle will have an impact on numerous commands, including even typing in coordinates.
In general that's an important method for keeping the UI uncluttered - having one option like setting the CPlane that when set adjusts how many other commands operate, instead of for example having a large number of special sub-commands.
Having tools work in combination with one another like that tends to help keep the UI streamlined.
Show messages: All  1-2  3-4
