Flow normal result ?
All  1-5  6-14
4539.6 In reply to 4539.4
Also in the next beta your original case without modifications will work better - I have some tuneups that help cases where things may be hanging out over the edge by a teeny tiny amount.
In the first v3 beta it can go kind of crazy if something is crossing over the base surface edge by a very small amount.
That's probably what is happening currently - if it ever finished calculating you probably would see a strange huge spike coming off of the bottom pole of the sphere. But that should not happen any more with the next beta.
It's still a good idea to try and avoid making things that squish an entire face down to a single point though.
4539.7 In reply to 4539.6
Thx for the infos
So waiting the next beta :)
For the moment best solution is to increase slicy the surface's size!
Because position of the object can be important for other thing :)
Kill the back face of the box don't works for me : calculate is done and finished but nothing is drawn :)
4539.8 In reply to 4539.7
It's the bottom face that you need to remove, not the back face - see the attachment here.
4539.9 In reply to 4539.8
looking forward to the next beta then. :-)
Peace,
Rich_Art. ;)
| C4DLounge.eu | Our Dutch/Belgium C4D forum. Cinema4D R13 Studio + VrayForC4D + UVLayout Pro + 3DCoat
4539.10 In reply to 4539.8
Effectively i have erased the bad face :D
Works fine with the good face :)
And the cool thing is this erased face becomes living in the result!
Is that normal?
4539.11 In reply to 4539.10
> Is that normal?
Sorry, I'm not sure if I understand this part...
The erased face becomes this totally squished down area in the result:
Ah yes as my sphere as the same color than the box, I don't seen the empty faces!
EDITED: 23 Sep 2011 by PILOU
4539.13 In reply to 4539.12
> At the start you have a box wihout a face (killed)
> At the end the box flowed has all faces around the sphere
Yes, that's correct - that's because the face that was empty is compressed down to a single line in the final result.
There are no new faces being created - each face in the original shape corresponds to a face in the final result.
4539.14 In reply to 4539.13
Ah yes! as my sphere as the same color than the box, I don't seen the empty faces! :)
It's for that I had believed that was magic!
Show messages: All  1-5  6-14
