Flow normal result ?
All  1-2  3-14
4539.3 In reply to 4539.1
Hi Pilou, also for a sphere the top and bottom "poles" of the sphere are areas where the sphere surface completely squishes down to a single point.
So similarly when doing a flow anything on the top or bottom edges of the base surface will also try to compress down to a single point and so it's not so good to have something like a plane surface running right along the top or bottom edge since that will then cause that plane to be squished into a point in the deformed result.
So for applying on to a sphere you probably want to have a bit of margin space area between the objects you are deforming and the top or bottom edge of the base plane.
It will also probably cause problems if you have bits of the objects being deformed actually sticking out past the top or bottom edge as well - I can't really tell just from the screenshot if that's what you've got in your case there. If you were to post a 3DM file instead of just a screenshot it would make it easier for me to give you some better advice though.
here the file http://piloumaison.weebly.com/uploads/3/6/2/0/3620514/dontwork.zip
I say don't work in a reasonable time on my computer
when the suface is bigger result is instantaneous and works fine (even very small bigger)
EDITED: 22 Sep 2011 by PILOU
4539.5 In reply to 4539.4
Hi Pilou, that's due to the bottom face of the box being mapped to the squished-together pole point of the sphere. That's because your object being deformed is touching the bottom edge of the plane here:
Move your object up slightly so there is a little bit of margin between the bottom edge of the plane, something like this:
Also see attached 3DM file.
If you leave a little bit of space in that area it will prevent the bottom face of the box from being squished totally down to nothing which is what seems to be causing the difficulty in your original case.
Another option is to delete the bottom face of your box - it's that bottom face that is trying to get squished into a single point that is causing the problem. If that face is deleted it seems that your original flow will then work without even leaving any margin space.
4539.6 In reply to 4539.4
Also in the next beta your original case without modifications will work better - I have some tuneups that help cases where things may be hanging out over the edge by a teeny tiny amount.
In the first v3 beta it can go kind of crazy if something is crossing over the base surface edge by a very small amount.
That's probably what is happening currently - if it ever finished calculating you probably would see a strange huge spike coming off of the bottom pole of the sphere. But that should not happen any more with the next beta.
It's still a good idea to try and avoid making things that squish an entire face down to a single point though.
4539.7 In reply to 4539.6
Thx for the infos
So waiting the next beta :)
For the moment best solution is to increase slicy the surface's size!
Because position of the object can be important for other thing :)
Kill the back face of the box don't works for me : calculate is done and finished but nothing is drawn :)
4539.8 In reply to 4539.7
It's the bottom face that you need to remove, not the back face - see the attachment here.
4539.9 In reply to 4539.8
looking forward to the next beta then. :-)
Peace,
Rich_Art. ;)
| C4DLounge.eu | Our Dutch/Belgium C4D forum. Cinema4D R13 Studio + VrayForC4D + UVLayout Pro + 3DCoat
4539.10 In reply to 4539.8
Effectively i have erased the bad face :D
Works fine with the good face :)
And the cool thing is this erased face becomes living in the result!
Is that normal?
4539.11 In reply to 4539.10
> Is that normal?
Sorry, I'm not sure if I understand this part...
The erased face becomes this totally squished down area in the result:
Ah yes as my sphere as the same color than the box, I don't seen the empty faces!
EDITED: 23 Sep 2011 by PILOU
4539.13 In reply to 4539.12
> At the start you have a box wihout a face (killed)
> At the end the box flowed has all faces around the sphere
Yes, that's correct - that's because the face that was empty is compressed down to a single line in the final result.
There are no new faces being created - each face in the original shape corresponds to a face in the final result.
4539.14 In reply to 4539.13
Ah yes! as my sphere as the same color than the box, I don't seen the empty faces! :)
It's for that I had believed that was magic!
Show messages: All  1-2  3-14
