Edit Style : erase all
All  1-4  5-9
4524.5 In reply to 4524.4
Or the script if I want keep my models with not yet colors attributed ;)
4524.6 In reply to 4524.5
You don't really need the script for that either - just select the objects that you want to keep and use Ctrl+C to copy them to the clipboard.
Then do File > New to get a clean start, and then Ctrl+V to paste those objects back in again.
Also another way to do it is to select the objects that you want to save and use File > Export to write them into a file, when you do Export it writes the selected objects to a file and in that file the only styles stored will be the ones that were used by those objects and not the full style list unlike "Save" or "Save As".
4524.7 In reply to 4524.6
Ok :)
So what is the use if the script?
ps
Clipboard has no limite of size except the memory free?
4524.8 In reply to 4524.7
Just another possible option if you want to have a keyboard shortcut for removing unused styles.
There are no special limits on the clipboard size. It does need to fit everything into one single chunk of memory though which may cause difficulties if you're trying to copy more than say 500MB of data that way.
4524.9 In reply to 4524.8
< for removing unused styles.
yep, that is the tip!
Show messages: All  1-4  5-9
