Edit Style : erase all
All  1  2-9
4524.2 In reply to 4524.1
Hi Pilou - if you only have a small number of styles just select one and push the Delete button a few times - each time you push it you will be deleting a style. It only takes about 2 seconds of doing this in the case you show there to delete all the styles.
If you have a large number of styles and you want to get rid of them all, then a better way to do that is to start a totally fresh model by going to File > New.
4524.3 In reply to 4524.2
I have asked after the gradient making that have easily 250 styles ;)
4524.4 In reply to 4524.3
So for that case use File > New to make a nice fresh start again.
4524.5 In reply to 4524.4
Or the script if I want keep my models with not yet colors attributed ;)
4524.6 In reply to 4524.5
You don't really need the script for that either - just select the objects that you want to keep and use Ctrl+C to copy them to the clipboard.
Then do File > New to get a clean start, and then Ctrl+V to paste those objects back in again.
Also another way to do it is to select the objects that you want to save and use File > Export to write them into a file, when you do Export it writes the selected objects to a file and in that file the only styles stored will be the ones that were used by those objects and not the full style list unlike "Save" or "Save As".
4524.7 In reply to 4524.6
Ok :)
So what is the use if the script?
ps
Clipboard has no limite of size except the memory free?
4524.8 In reply to 4524.7
Just another possible option if you want to have a keyboard shortcut for removing unused styles.
There are no special limits on the clipboard size. It does need to fit everything into one single chunk of memory though which may cause difficulties if you're trying to copy more than say 500MB of data that way.
4524.9 In reply to 4524.8
< for removing unused styles.
yep, that is the tip!
Show messages: All  1  2-9
