EggHalf Parametric Script
All  1-3  4-6
4489.4 In reply to 4489.3
I tried to run the script (EggHalf.js), by starting up MoI with the script as a parameter, but I get a Script error which states "Line 30 Column 1:".
I have never executed a script from MoI before, so I am not positive that I am doing it correctly. Can someone lend a helping hand?
4489.5 In reply to 4489.4
Hi YHWH_777 - these scripts are meant to be as a command - when you give a .js as a command line parameter that's trying to execute the script on program startup which is a bit different kind of thing.
For this one, copy the 2 files EggHalf.htm and EggHalf.js to the \commands sub-folder underneath MoI's main installation folder.
That will then make a new command named EggHalf available for MoI to run - to launch it either type Tab and type the command name and push enter, or set up a shortcut key with that name in the command column for the shortcut.
4489.6 In reply to 4489.5
Thanks for the explanation. It works fine now.
Show messages: All  1-3  4-6
