Does anybody Use Carrara 5
All  1  2-7
448.2 In reply to 448.1
Try this forum for Carrara: http://forums.polyloop.net/carrara-eng/
> I'm almost positive Steph3D is a Carrara user,
If I remember right, I think he uses Cinema4D a lot.
> Frenchy for goodness sake step in here and help a brother out.
I think Pilou is out on vacation somewhere, no doubt suffering from Internet withdrawal. I think he said something about being back on the 5th or 6th or so.
448.3 In reply to 448.2
Thanks Michael
-Matt
448.4
Hi. I haven't used it for Moi. But i have imported some of my Rhino 3DM files into Carrara for render. I find that Carrara's mesher is not so great. the options are extremely limited, and the same setting is applied to all objects in the file. So i decided it's better to mesh everything in Rhino, and then import the obj's to Carrara... That was before Moi. Now I would prefer to mesh the Rhino models in Moi, as Carrara has pretty good support of n-gons...
jonah
448.5
I use Carrara 5 for almost all of my MoI objects. To UV an area for a logo for instance just go to the vertex modeler room and select the ploys you want to label and assign them a shading domain. Then open the UV tools and map just the shading domain you just made. Now go to the shader and use a complex layer shader instead of a multi-channel, add a basic layer assign it to the shading domain you want and import your UV map to the color channel. I hope this helps.
Here is a thread from a similar question
http://forums.polyloop.net/3d-work-progress-finished-works/10687-hydraulic-connector-moi-carrara.html
448.6 In reply to 448.5
Thank you Grendel, very helpful. Its gonna take some experimentation but I think I got the jist.
-Matt
The french artist Marcel Laverdet use Carrara for render quasi all images
(it's also a master of Rhino :) So you will have no difficulties to export to Carrara from Moi!
see his album http://www.zbrushcentral.com/zbc/showthread.php?t=34679&highlight=albums
EDITED: 4 Mar 2007 by PILOU
Show messages: All  1  2-7
