Saving shortcuts
All  1  2-3
4476.2 In reply to 4476.1
Hi Felix - all shortcuts and option parameters are automatically saved when you exit MoI.
But one thing that can potentially mess things up is if you open up 2 instances of MoI and then edit options in one of them - each instance will write out its settings when it closes so the last one closed will be the one that will end up in moi.ini
So if you're editing settings or shortcuts, close down any other running instances of MoI first.
4476.3 In reply to 4476.2
I miss the exit or close Moi autosave options thing because I'm often using a couple of Moi session. Most have been closing the wrong one all this time.
Felix
Show messages: All  1  2-3
