Flow weirdness
All  1-9  10-13
4474.10 In reply to 4474.9
Hi Mike,
> The easiest example I could think of at the moment would be
> block type being flowed on a surface with convolutions in all
> directions.
Well I mean do you have an actual model example that would match with what you're describing here?
Like for example what kind of object do you want to create where you would need this particular thing in order to finish it.
I understand that it's possible to come up with some theoretical shapes that would require it - but I'm more interested to know how this would have helped some of your already existing modeling work rather than just how it would enable some esoteric theoretical situation.
For example, are there any physical objects that have these characteristics which that particular option would help to create? If you have any links to examples like that it would help!
Basically if I can understand how a new option opens up a new avenue of usefulness for things that people actually are trying to build, then that carries a lot more weight than just "it would be kind of cool"...
Adding too many things that are primarily based on "cool factor" and not on actual "usefulness factor" is a pretty good way to end up with a complex UI that is loaded with stuff that only applies to special case situations.
The problem is that a complex UI comes with a cost in reduced ease of use.
4474.11 In reply to 4474.10
Yes, yes, I do agree with your point. And nothing is as scary in the 3D modeling world as the side panes in 3DS Max! (Whoa!)
Where every feature in the book has been added.
I don't have anything handy to show, just a seed of a notion from the recesses of my inner-mind, considering the possibilities. ;-)
But this is the positive side of this forum and the whole beta testing thing: If its a good seed then it will grow, if not, better to cast it off now, than to try and prune the wild tree later.
4474.12 In reply to 4474.11
Hi Mike, let me know in the future if it clicks for use with a particular model!
And yes - it's especially a good time during the beta period to discuss new ideas, particularly for the tools that are right now under development.
4474.13 In reply to 4474.4
>> Yup, I just finished up that part for the next v3 beta. In the next beta it will pay attention to where you click on both surfaces and it will match the uv directions so that the edges that you clicked near are aligned to one another, you click near to one side of an edge.
Sounds perfect !
Show messages: All  1-9  10-13
