point array on path
I must be missing something.. I thought that array on curve would array this point along the path?? I get them scattered all over off the path.. Wether I use autoplace or place the point on the path... If I missed something, let me know..
4467.2 In reply to 4467.1
Hi Burr, well it does actually array it along the path but because your point is located off of the curve there is a kind of offset distance that comes into play where each copied version is at that same distance away from the curve.
With only a few points being generated it will be kind of hard to see the pattern - try making something like 100 copies (set Item count option to 100) and then you should see the pattern of how it is tracing along a kind of offset curve.
To get more control over something like this you probably want to make a curve that the point is sitting on to array along rather than having one that is a fair distance away from it which will involve that kind of offsetting.
4467.3 In reply to 4467.2
Oh darn... I thought I put the point on the path also and got the scattered results... I must have had it still off the curve somehow... (tired)
Point arrays on curve as expected when point is "on path" to start...
