how to make a bendy strip?
All  1-2  3-7
4466.3
Yes, the Sweep command would be the best to use:
Draw your profile - Rounded edges.
Make lines that are offset for the bent sections of the metal strap...
Move the two small lines down and over to represent the edge of the bent section...
Blend the ends of the profile and the lines to get a smooth transition...
Merge the whole thing - Copy and Rotate to make a pair...
Position the copy so that the bottom is as far in one direction as the top ends are in the other...
Make a rounded Rectangle...
Sweep the rectangle using both profiles as a path (2 Path Sweep)...
...There you go... You may need to adjust the transition path to make the bent section work best.
4466.4 In reply to 4466.2
THANK YOU!
EDITED: 20 Feb 2022 by TWOFOOT
4466.5 In reply to 4466.4
Here's another method:
4466.6 In reply to 4466.5
@ Bur : Very cool method!
ps You must increase the speaker level when you reccord for the next time ;)
Because even I put to the max, slider of my headphone, slider of the speaker Windows taskbarre, slider of the youtube speaker
I have only a charming sepulcral carvernous distant voice :)
4466.7 In reply to 4466.6
Hey Frenchy, Thanks... (the swept arc would need to be done different to keep tangency)
Ah, the volume.. I used "headphones" and didnt consider that through speakers would be harder to hear.. I suppose I could turn up the mic a bit. Although, then you would here my wife chiming across the rooms "Get in the bathtub!!!" to my kids.. lol
Show messages: All  1-2  3-7
