A bit off topic
All  1-2  3-5
4459.3 In reply to 4459.2
Yeah, I used charmap, and it doesnt find anything.
So your forum here renders that character into the post.. Then if I select and copy it from the forum, I can insert that into Notepad.. Am I clipboarding that binary value??
I'll try a binary hex edit then.. Thanks for the info!!!!
4459.4 In reply to 4459.3
> binary value??
Yup, well you're actually clipboarding unicode text - that's CF_UNICODETEXT format:
http://msdn.microsoft.com/en-us/library/ms649013%28VS.85%29.aspx
When you paste that into notepad, you now have text that is not really representable in ascii anymore since you now have a character in your text that does not match to the limited set of ascii characters that you can see in that table I linked to before.
If you decide to save out to an ascii file from notepad, I guess it could write out the numeric value for that character anyway, but it looks like that is actually reserved in ascii for a message to control hardware devices and isn't supposed to be a printable character in ascii.
If you want to edit a file where you are controlling the raw number values of every byte in the file, you usually want to use a hex file editor to that kind of job rather than a text file editor though. A regular ascii text file editor would probably not let you make that character since it does not correspond to a printable character in the ascii table.
4459.5 In reply to 4459.4
Thanks for the time Michael... :)
Show messages: All  1-2  3-5
