Sketch in MoI, Catenary wire hanging from 2 unequal height points.
Cannot seem to get Alibre to import any 2D curve from MoI, except for inserting a pipe per Ralf, so had some fun using MoI to sketch some Catenary variables.
The arrowheads are 3 sided polygons
4458.2 In reply to 4458.1
Hi Brian, it seems to work to export curves to Alibre using SAT format.
If I remember right there may be something that they don't like to load files that have some mixture of both curves and surface/solids within the same file.
So try making an SAT file that contains only curves in it and you may be able to get those over.
4458.3 In reply to 4458.1
Hi Brian, also it looks like you already found this but just in case anyone else is reading this and wants to know how to import curves into Alibre, there is also a different "insert surface" import method that can also bring in curves as well, which Ralf explains here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=3354.4
But a regular import of SAT format seems to work also.
4458.4 In reply to 4458.2
SAT format for a Catenary worked for Import to Alibre!
Thankyou.
