 1-18  …  619-638  639-658  659-678  679-698  699-718  …  2659-2669
4446.659 In reply to 4446.658
<< What PNG file would you expect to be generated from MoI's OBJ export?
Colors Style of works used during the modelisation inside MOi...
like following (not exactly the same because i have not more the modified object (at ends' arm/ hands)
But i must continue to investigate!
MagicaVoxel create 3 files OBJ, Mtl and PNG file : this last one is one horizontal line of the 256 or less colors used !
It's this png file that i have artificially add inside the 2 files created by MOi and magically object will have colors!
Mixamo ask a zip file of these 3 files!
Here result with the artificially Moi 3 Files zipped :)
EDITED: 6 Mar 2019 by PILOU
But I must make some tests more!
4446.661 In reply to 4446.659
There isn't anything in the OBJ format spec that says that there should be such a bitmap file created along with the .obj file. It's probably something unique to MagicaVoxel.
4446.662 In reply to 4446.661
Seems i have dreamed...seems the 2 files OBJ MTL are sufficient...from MOI!
Here with 2 colors that's works with only OBJ + MTL!
EDITED: 8 Mar 2019 by PILOU
Ok this time that must works! thx to Makio! https://twitter.com/makio135
Just put an image PNG with a transparent background (empty spaces)
Full Screen https://editor.p5js.org/Pilou/full/y1GHaBqyT
https://editor.p5js.org/Pilou/sketches/y1GHaBqyT directly in the editor (you can modify it if you are not cardiac! :)
or put your image here by Drag & Drop on your screen : save it as you want with Right Click on the image
Have fun! You can put any number of images you want!
etc...
EDITED: 14 Mar 2019 by PILOU
and of course with any moi objects' image! ;) Flipper's buttons of the golden age ? :)
Magica here ;)
EDITED: 15 Mar 2019 by PILOU
Wonderful!
https://www.nvidia.com/en-us/deep-learning-ai/ Infos on AI from NVidia!
Test Play Ground in direct online...and other wonders!
https://www.nvidia.com/en-us/research/ai-playground/
I have tested the IA on clear foreground : can be some better but it's the beginning! :)
this technique is not so new (Image Inpainting)
I can do this also with Photoshop CC 2019 on 3D models
with textures applied, to get rid, for example, of seams. ;-)
A funny workflow :)
Use the Free Bricsys Shape https://www.bricsys.com/en-us/shape/ (a tricky ergonomy - not sure i all understand but...
you can take also Moi of course! ;)
Make a little drawing (10 seconds) with the Quick Draw function (first icon :)
Take a Snap Shot image - make a PNG image with transparent background (some white surfaces) with any 2D Prog
And Drag & Drop the result on my little prog some posts above! https://moi3d.com/forum/index.php?webtag=MOI&msg=4446.663
Right Click Save image and voilà! :)
Of course that is infinite because you can draw anything you want! : Only your imagination can limit the process! :)
EDITED: 22 Mar 2019 by PILOU
A very famous city! ;) (MagicVoxel)
4446.671
Wow, great....
Always amazing!
G'MIC https://gmic.eu
Add 482 Image Filters to: GIMP, Krita, Paint.net...
Aespecially G'MIC/Artistic/Stylise who avoid to go to these on line deep learning progs! ;)
https://www.ostagram.me
https://dreamscopeapp.com /
https://deepdreamgenerator.com/
EDITED: 5 Apr 2019 by PILOU
Cool Pilou!
Here are two self portraits which uses reaction diffusion.
You can do this with Ready, KPT Reaction Filter or reactor.exe
and then one must make a color mesh of it to render it.
me1
me2
EDITED: 18 Mar 2022 by MICHAEL GIBSON
Very convincing!
Yes, i think so too.
Working on a MoI vector / NURBS version …
Wish me luck that I can later make a nice mesh out of it.
Otherwise I have a nice vector technique for T-Shirt or Poster prints … :-)
me-moi-reaction-diffusion
EDITED: 6 Apr 2019 by STEFAN
Finally finished the drawing and creation of the surfaces.
Was quite a bit of work, but I enjoyed it due to the fact
that MoI is such a cool and fun app.
me-final-drawing
Show messages:  1-18  …  599-618  619-638  639-658  659-678  679-698  699-718  719-738  …  2659-2669
