 1-12  …  573-592  593-612  613-632  633-652  653-672  …  2693-2702
4446.613 In reply to 4446.612
Very interesting!!
But I suppose that in order to get a "smooth" result you have to generate hundreds of frames if you want to create some video to at least 25fps.
4446.614 In reply to 4446.613
Just 72 images will be sufficient! Above it's just 24 images! ;)
here a test with an image 6 000 * 6 000 pixels (now you can have 12 000 * 12 000)
(i believe that must be a little deformation because the original was 960*800)
4446.616 In reply to 4446.615
Very good!
Print it on a t-shirt ;)
4446.617
Pilou, these are very dreamy. They remind me of some abstract exploration games like fract, NaissanceE or antichamber and make me want to walk around.
With a SkektchUp Make Model with a cool Plugin DeckBuilder by SDMitch :) (All is free! )
And Zarbuz tools!
I was blocked on the size by the Gif creator that i used (original was at hte double so 960 * 800 ! )
72 images this follow is 5.5 megas - 20 minutes to render at the double size (that some long for me! :)
EDITED: 4 Feb 2019 by PILOU
Another test :)
(36 images) Maybe a little speedy :)
format mp4 is possible (1 /8 of a Gif size! ) but i don't know how to put it in this forum ?
EDITED: 8 Feb 2019 by PILOU
with an image by Aryaneire
Test with the new mp4 video syntax of Moi! (Gif = 9.3 megas , mp4 = 538 KB)
put following line between < and>
video controls="true" src="your mp4 image adress hosted"></video
right Click on the image for have some more controls!
4446.621 In reply to 4446.620
Really COOL!!
How funny how a simple cube can be rendered! :)
4446.623 In reply to 4446.622
What is it? ...a mysterious object :)
maybe interesting for you too ...
https://github.com/tommyettinger/IsoVoxel
4446.625 In reply to 4446.624
Thx but i have yet that on my site from the beginning! ;) (in French of course :)
http://moiscript.weebly.com/isovoxel.html
With a Chipp Walter crash-test mannequin model! ;)
Another test...
Right Clck on the image for more controls!
EDITED: 9 Feb 2019 by PILOU
4446.628 In reply to 4446.627
Great JOB!!!
Another test
Right Click on the image for more controls!
You walk in a luxurious jungle!
Always jungle! :)
With a little piece of the above image and a triple loops of Processing :)
I believe that you can change anything you want aespecially t between 1 - 50, the coef of k 1 - 5 etc...
Tell me if that work for you in direct on the fly ! Press the black triangle inside the yellow disc!
Then change the code...
A cool thing that this Web Editor!
https://editor.p5js.org/Pilou/sketches/PE_HwNoXH
EDITED: 12 Feb 2019 by PILOU
4446.632 In reply to 4446.631
Interesting...
@You : "...Tell me if that work for you..."
Yes! It works :)
Thanks.
Show messages:  1-12  …  553-572  573-592  593-612  613-632  633-652  653-672  673-692  …  2693-2702
