 1-16  17-36  37-56  57-76  77-96  …  2697-2699
4446.37
Cool, Pilou! Did you already put Max's subdiv script to the test with such a structure?
metinseven.com — 3D (print) modeling • animation • artwork • design • illustration • visualization
4446.38 In reply to 4446.37
Yes of course ;)
But if the direct import of OBJ is perfect, I am not sure that the Subdivide can make something without some simplify or tricky manipulation
because it's real "Voxels" ! So some cubes or more some facetts! ;)
I must find some workaround first! :)
As it's facets Boolean Union will be the solution - but not sure that wotks for a such number of facetts in a reasonable time!
EDITED: 7 Oct 2014 by PILOU
A Possible workaround :)
MagicaVoxel
Import inside Sketchup as OBJ or 3DS
Cleanup By Thomthom
Export as OBJ By TIG
_importObj By Max Smirnov inside MOi
Explode - Boolean Union
EDITED: 8 Oct 2014 by PILOU
4446.40
I love these kinds of experiments. Paint3D has an option to weld vertices before exporting to Obj, so you've got one manifold mesh with the outer voxel sides as quad polygons. Very suitable for subdivision, to get nice filleted edges.
Edit http://moi3d.com/forum/index.php?webtag=MOI&msg=4446.163 See here for the 0.99 (nov 2017)
Magica Voxels ---> obj ---> Moi :)
http://voxel.codeplex.com/ MagicaVoxel
_Importobj by Max Smirnov
Explodemove by Michael Gibson ;) (20 150 surfaces! )
EDITED: 1 Dec 2017 by PILOU
4446.42 In reply to 4446.41
Cool!
http://voxel.codeplex.com/ MagicaVoxel 0.94
MagicaVoxel0.98 (thx Shadows44) new version with Animation (24 Frames)
http://ephtracy.github.io/index.html?page=mv_main
viewer /render for volumes 2048*2048*2048 or Minecraft files!
http://ephtracy.github.io/index.html?page=mv_renderer
You can import Moi OBJ Model inside! :)
EDITED: 31 Oct 2016 by PILOU
4446.46 In reply to 4446.45
Yes! Magica Voxel and its Viewer are a couple of absolutely amazing software!!
With them its possible to create very funny things and they are perfect companions for Moi!
best,
Big remark!
_importObj and Subdivide by Max Smirnov makes also the trick inside Moi!
And you have Nurbs! ;)
A little more tortured but ...its by Plugin! Always astonished by what makes this Max's Plugin!
And you can re-Subdivide some times! :) (always with Max Sudivide plugin)
EDITED: 1 Nov 2016 by PILOU
4446.50 In reply to 4446.49
Goxel or magicaVoxel ?
Marco (mkdm)
EDITED: 1 Jun 2017 by MKDM
4446.51 In reply to 4446.50
Previous post MagicaVoxel with SketchUp , Moi! ;)
Ps Goxel is made by a French guy! I have made the French code manual! ;)
http://moiscript.weebly.com/goxel.html
here modeling Goxel ;)
(Speedy render by the free Simlab Composer Light (max 1920 * 1080) :
http://www.simlab-soft.com/3d-products/simlab-composer-lite.aspx
EDITED: 1 Jun 2017 by PILOU
4446.52 In reply to 4446.51
Thanks a lot Pilou for the info.
Very interesting the Goxel script language manual!
Is there an English version ? (I don't speak french...)
4446.53 In reply to 4446.52
4446.54 In reply to 4446.53
Thanks a lot :)
4446.55 In reply to 4446.53
Great info, thanks Frenchy
Do you ever sleep? ... seems like you are always coming up with new stuff.
4446.56 In reply to 4446.55
Some insomiac indeed! :)
Show messages:  1-16  17-36  37-56  57-76  77-96  97-116  …  2697-2699
