Moving and resizing boolean holes
All  1-4  5-7
444.5 In reply to 444.4
To fix trimmed holes, would it be possible to incorporate an "Untrim" command
as in Rhino? If so, how would that work in regards to History Update?
-Jesse
444.6 In reply to 444.5
> "Untrim" command as in Rhino?
Hi Jesse - in MoI untrim is built in to the regular Delete command.
To untrim, you select all the edges of a trimming boundary, and hit delete, that will remove them same as Untrim. The edges will only be removed if they are not attached to anything else.
Well, there aren't very many situations where history would come into play with this, because most of the operations that you would do with a face like this like join or booleans, don't work with history right now.
Is there some particular situation with history that you're interested in with untrim?
444.7 In reply to 444.6
I guess if history could remember the trims, joins and deletes that go into a Boolean operation and sort them out, untrim
could undo the effect of a Boolean on a particular surface without acting on other surfaces that were involved in the Boolean.
This comes into play when a client sends me a .3dm file to mill that isn't built correctly and asks for my assistance in repairing/rebuilding it.
Essentially, after untrimming a surface, I usually delete it and use the edge curves of the rest of the model to rebuild the section, but at least it can save me from the impossible task of pick out a lot of little surfaces to delete while making sure they all belonged to the surface in question and not something else. For instance, when a surface has been pierced and cut up in many places such as on a polysurface of a ring with multiple little stone settings or other small embellishments added or subtracted. The stone settings and other parts can also be untrimmed and restored to their original state, so I can fix something pretty quickly, without having access to, or even needing to deal with the original construction curves (which probably caused the problem in the first place).
Jesse
Show messages: All  1-4  5-7
