Backup revisited
4433.1
I save often while I work but I wish now I could get back to a version I made a few saves away.
Undo is not an option since I left the program and it is when I came back to it that I realize I had accidentally deleted some part of my work.
What is the usual way to deal with this kind of situation?
One way could be to create a new version every time a save is done. Keeping a number of past saves on disk. That would be really handy today.
Gaston
4433.2 In reply to 4433.1
Hi Gaston, yes normally the way to solve that is by saving to a different version every once in a while so you have numerous versions as different 3DM files on disk instead of only one single file.
There is a command that can help you with that called IncrementalSave:
http://moi3d.com/2.0/docs/moi_command_reference10.htm#incrementalsave
One way to use it is to go to Options > Shortcut keys, and add in a new shortcut like maybe Alt+S and for the command name put in IncrementalSave
Then when you wanted to save to a new file push Alt+S and it will save your file to a new name with an incremented number in the name, like myfile1.3dm, myfile2.3dm , etc...
I am also interested in trying to make undos be persistent instead of being only for one modeling session. The tricky part about that is that it will probably make for a pretty large additional file that has all that information stored in it.
4433.3 In reply to 4433.2
As always, there is an easy way to do things in Moi :)
That is great. If I had remembered that feature, all I would have had to do is cut and paste the deleted parts from a previous version.
Gosh I like this program :)
Thanks Michael,
Gaston
