ToroidKnots Script
All  1-5  6-12
4430.6 In reply to 4430.5
Frenchy oughta go nuts with this one!!!! :o Very cool.
4430.7 In reply to 4430.5
Wow
How is this moving UV texture done on a Knot?
Thankyou
4430.8
Thanks Guys, it's pretty easy to set up if you have animation software that can keyframe your
texture's U/V position. I set this up in trueSpace 7.61 because it renders animation fast (3-4 frames/sec.)
Moi NURBS create great UVs from a sweep with poly export so all you need to do is apply your texture &
keyframe the UVs from 0 to 1 for each rotation.
Modo has a similar setup, U & V offset is keyframed/animated.
4430.9
Reworked this animation so it was a little less snake like. ;)
Rope Knot from danperk on Vimeo.
4430.10 In reply to 4430.9
Kind of hypnotic!
4430.11
As the Worm Turns...
Eye catching, yet slightly dizzying.
Cool!
Show messages: All  1-5  6-12
