photos to 3D model? (objects and not architecture)
All  1-3  4-11
4421.4 In reply to 4421.2
Thanks Micheal.
I realize that the data will be a mesh but can't I import as obj or dxf reference and rebuild surfaces with MOI? In other words, will MOI's tool be able to snap points to the scan data? Say I scan in a chess piece. The import will be obj/dxf but can I draw a contour with control points snapping to the imported model?
-Dooki
4421.5 In reply to 4421.3
Thanks Magic. Looks cool but unfortunately I am working on organic forms and not straight sides as with architecture. Thanks though!
-Dooki
4421.6 In reply to 4421.4
Hi dooki - well MoI does not currently import OBJ or DXF data - MoI currently is not focused on working with polygon model data at all for its own modeling workflow, only on generating polygon output at export time.
See here for some previous discussions:
http://moi3d.com/forum/index.php?webtag=MOI&msg=3468.2
http://moi3d.com/forum/index.php?webtag=MOI&msg=1578.7
http://moi3d.com/forum/index.php?webtag=MOI&msg=3044.2
http://moi3d.com/forum/index.php?webtag=MOI&msg=4104.1
One thing that you can do is to use the OBJ converter program from here:
http://moi3d.com/wiki/Resources#Obj23dmWireframe_converter
That converter will read an OBJ file and then generate all of the polygon edges it finds into it as line segments in a 3DM file, then you can open that wireframe 3DM file in MoI to use as a snapping guide.
4421.7 In reply to 4421.6
Photosculpt http://www.photosculpt.net/ uses 2 pictures to build a model, currently focused on capturing 3d textures rather than an entire model. The developer is working to address full 360 degree capture as well as adding calibration for more accurate data. Right now there is some distortion present in the models, so its probably not best suited for this purpose, but it is something to keep an eye on.
There's a few applications here that are photo based http://www.agisoft.ru/ . One uses multiple images to construct a full 360 degree model, and another that works with image pairs.
4421.8 In reply to 4421.6
Oooo, thank you sir!
-Dooki
4421.9 In reply to 4421.7
Thanks Chris!
-Dooki
Maybe Project Photofly from Autodesk is also something for you.
http://labs.autodesk.com/utilities/photo_scene_editor/
4421.11 In reply to 4421.10
Oooo, thanks Stefan. This looks interesting.
-Dooki
Show messages: All  1-3  4-11
