problems with "routing"
All  1-5  6-18
4404.6 In reply to 4404.3
The other way you can do it is to do the boolean union and delete the bad faces (looks like they have messed up trimming boundaries somehow) and then contruct a new replacement face by selecting this edge down here and extruding it up:
Then join the extrusion to the other pieces to make a finished solid - that's what I did to get the unioned result in the attached 3DM file.
4404.7 In reply to 4404.6
Michael, I tried that, plus a Loft and a Network. There were even segments that I had to Merge (curves).
But for some reason, the new surface refused to Join to the existing structure.
4404.8
Thanks everyone. I'm sorry I have so many "pieces" in my model. I'm trying to save everything in case I have to rebuild things. Which I've already done a few times. BTW, I didn't fillet the solids before routing.
Yes, trem rout is the stuff related to the routing of the trem pocket. I think I left the curves with the extrusion used to create the solids. I believe when you extrude from curves the curves are left behind.
I was going to try different paths to try and fix this, but I wanted to make I knew what was messing things up first. Looks like boolean diff got confused when I used the multiple solids. Also, merging via boolean union got confused because of the coincident surfaces. I thought boolean union liked it when you "bury" one solid into another. I guess this isn't the case when you share large regions of surfaces.
I'll try trimming and union and also the project and extrude methods to get some practice making the "routing" solid.
Thanks again!
4404.9 In reply to 4404.7
Hi Mike,
You've got to remove the existing bad surfaces first - the area that looks like holes actually has some surfaces there, but they have a mangled trimming boundary so their display is messed up.
So to fix that you've got to do an Edit > Separate first to break the thing into individual surfaces, then do a window select (with the "inside only mode" - start in the upper left corner and drag to the right) to capture the bad faces and delete them. Then you'll have an actual open space there that can have something joined in.
Otherwise if you don't delete the bad ones the edges there are already joined between 2 surfaces and that's why they would not accept any new joins in there because if they did join in that would be trying to have edges shared by 3 surfaces instead of just 2 surfaces.
4404.10
I also tried repairing the body after doing the boolean diff, but that experience didn't go well.
4404.11 In reply to 4404.10
Thanks Michael. That may explain the problems I had with trying to repair the solid and the body.
I forgot some of the things I tried since its been a while since I last had free time to work on this model.
Hope to someday build this thing on my Carvewright.
4404.12 In reply to 4404.10
Hi Jeff,
That was probably the same issue - the thing that looked like a hole was not quite exactly a regular open hole but actually a surface with a messed up trimming boundary. That needs to be removed so you really have a hole there that can then be patched up.
It's a bit of a tricky operation to select a messed up face like that since it doesn't have any of the regular shaded display to it to click on (that's a side effect of having a messed up trimming boundary - messed up trimming means messed up display meshing will happen as well) - instead you have to do a strategic window select around it to select it and then delete it.
4404.13 In reply to 4404.10
Interesting, Michael.
I noticed something strange about those broken segments, a sign of something more off.
I'm sure it's because the body inherited the existing messed up surfaces.
4404.14 In reply to 4404.12
Also, this issue must also be akin to the instances when I perform a trim of some sort and end up with the random looking naked surface squares.
4404.15
The easiest way to fix this is to draw a line straight across from a side view level with the top. Then move the smaller block so it sits exactly on top of the bigger one. Boolean union will then work. Then cut the top back to size with a boolean diff using the line you drew first. Delete the top solid.
4404.16 In reply to 4404.14
Hi Mike,
Yeah most likely those were also messed up trimming boundaries. Any kind of manglement in the trimming boundary will make for odd display mesh generation like that. That could be stuff like parts of the trimming boundary crossing over itself making a self-intersection.
So in this case there appears to be a bug in the boolean handling where it's keeping the wrong surface piece.
This kind of ghost surface piece here:
When you turn on its surface control points, the control points for the actual surface are way up here:
So the trimming boundary is totally off of the surface - the trimming boundary itself is in the right spot for the boolean result but the boolean seems to have decided to keep the wrong surface piece as the underlying surface part of the face.
This is a simple enough case that I may have a good shot at tracking it down and fixing it, I'll give it a try in a bit.
4404.18 In reply to 4404.17
I resurfaced the 4 fillet corners of this object and the boolean succeeded. FYI
Show messages: All  1-5  6-18
