Import Point Script Error
 1-11  …  72-91  92-111  112-123
4381.112 In reply to 4381.111
Hi Frenchy,
The file imports OK to Powershape.
"Exchange" is the translator program Powershape-e uses. It is a seperate download. It will show up on the welcome menu in Powershape and is free to download and use. It is also their system for creating "Vouchers" that will be used if you want to pay for your model "Translation out" of Powershape...
Be sure to download and install both programs to use it properley (Latest versions).
Go to "View/toolbars/explorer" and clcik on the browser tab in the explorer window.
Note: You dont have to open and use exchange, it just needs to be installed. Then Powershape will use it when doing imports of different formats.
4381.113 In reply to 4381.112
Thx for the infos !
4381.114 In reply to 4381.112
@ BUR: Works fine !
It's funny to load something more of 100 megas for a translator ;) But That works fine now for 3dm format! ;)
It's cool for see if something is wrong on a volume / surface !
4381.115 In reply to 4381.114
Hi Frenchy,
Yes, it has extensive analysis/repair tools. The program is heavy though.. I doubt it would run on a normal desktop.
4381.116 In reply to 4381.115
@ Bur: Works on Latop (3 years) :)
(i test also 1234D and Co Create (all works in free version and against PowerShape you can "export" files different than native one ;)
Both have funny ergonomy!
http://www.123dapp.com/
http://www.ptc.com/
EDITED: 25 Jul 2011 by PILOU
4381.117 In reply to 4381.116
Oh thats good news.. I guess I loaded it on an old P4 with 1 gig of ram and it didnt run too well. But that is REALLY old.
4381.118
For some reason when I updated this model I had no trouble at all adding a fillet to the blade/hub joint. This is what I originally wanted but it would never work in Rhino or MoI. In MoI, I could at least transition from the hub to blade as previously posted. Here it is a much better blend between the two. I believe it was a 1mm G1 Fillet, if not, it was something close to that. I followed the same process as always. The input data is slightly different though, not sure if that had anything to do with it.
Edit; The attachment has been removed to save server space. My final product, from this thread, is available on my website at http://propdesign.weebly.com/. Look for MoI_Example.zip.
About Co Create ;)
This video is some crazzy ! Of course not in the free version ;)
http://www.youtube.com/watch?v=XHOnhB3bPjI&feature=player_embedded
http://www.ptc.com/products/creo-elements-direct/modeling-express/ free version
Here that you can make with the free version
video http://www.youtube.com/watch?v=CmLwE104qn0 ;)
4381.120 In reply to 4381.7
Michael G,
The updated import file script you provided is not the same one on the website. Is it ok if I provide this script on my website, for PROP_DESIGN users.
Anthony
4381.121 In reply to 4381.120
Hi Anthony,
> PROP_DESIGN users.
Certainly that's fine!
4381.122 In reply to 4381.121
Thanks Michael and Happy New Year to you.
4381.123 In reply to 4381.122
Happy New Year, Anthony!
Show messages:  1-11  …  52-71  72-91  92-111  112-123
