Extruding a solid
All  1  2-5
4367.2 In reply to 4367.1
Your curves are not clean!
Overlapsed and not well connected at some extremities!
4367.3 In reply to 4367.1
Hi Mark - so it looks like the problem is that your curve is open and not a closed curve.
Note that when you select a closed curve, the type will actually read as "Closed crv" like shown here with a circle selected:
Since when your curve is selected it just says plain "Curve" as the type, that means it is an open curve, so there is a little space somewhere in it between the start of the first segment and the end of the last segment.
There is a plug-in you can install called "MarkOpenCurveStart" which will let you set up a keyboard shortcut that will create a point object at the start location of a curve - that can help you figure out which area to zoom in on to see where the opening is at. I guess Pilou is showing there that instead of a gap in that spot it's more like the sides cross over each other at that spot.
You can get MarkOpenCurveStart from here:
http://moi3d.com/forum/messages.php?webtag=MOI&msg=2888.11
It's here the problem ;)
Make zoom / show point and you will see that curve is not closed
4367.5 In reply to 4367.1
Hi Mark, just to help clarify a couple more screenshots:
If you can get that area cleaned up so that it is a completely closed curve then it should extrude as a solid with end caps on it.
Show messages: All  1  2-5
