import
All  1-2  3-7
4365.3 In reply to 4365.2
Thanks Michael ...
I will check that out right after my lunch break!
cheers,
eric
4365.4 In reply to 4365.3
Hi eric, also one other note - if you find yourself using the same file over and over again you can set up a shortcut key that will do an ImportPart of a specific file so you won't have to use the regular file dialog.
To do that set up a keyboard shortcut and for the command name put in ImportPart followed by the file name, like this:
ImportPart "c:\some folder\my filename.3dm"
4365.5 In reply to 4365.4
Thanks Michael ..
The 'import' file with a right click works just great ... I have been building a few window and door types that I can now insert when I need them and put them where I want them.
MoI is great!
cheers,
eric
ps ... ever anticipating ... can hardly wait for ver 3
4365.6 In reply to 4365.5
Hi eric, I'm glad that the right-click import will work for you!
One of the things I've just finished for v3 is updating the OpenNURBS library that MoI uses to the latest version. That means that MoI v3 should be able to preserve stuff like linestyles when you open and save a Rhino v4 file and it can also now open up Rhino v5 files as well.
4365.7 In reply to 4365.6
Hi Michael ..
That's great news ... I use Rhino 5 for drafting ... I will be delighted not to have to remember to save as R4 everytime.
cheers,
eric
Show messages: All  1-2  3-7
