Do you feel it?
 1-13  …  94-113  114-133  134-153  154-173  174-193  …  234-250
4363.134 In reply to 4363.131
Hi Ed,
> Will there be a way to inset and subtract the applied object?
> That is, wrap text onto a sphere and make it look like it is
> engraved (recessed) into the sphere?
Yes, you just use the regular Boolean commands after you've made the transformed object.
Use Boolean difference for example to cut the objects away from the base, or Boolean union to cut off the interior parts and leave the pieces that protrude to the outside.
> I see how this could be done as a multi-step manual process
> after the letters are morphed, but it would be cool to have
> function that does this.
It's just one more step to use the boolean command to get what you need after the transformation.
Adding too many things directly into a single command that can already be handled by a combination of some existing tools tends to make that command get complicated and end up with too many options inside of it.
It just generally helps to keep complexity down when you can use a couple of different commands in combination with one another to get the final result that you need. That helps make each individual command a bit more simple with fewer stages and UI within each one.
It's the same reason why there isn't a Boolean option built into other transform commands like the rotate or move commands, etc...
But maybe that could eventually be a plug-in that had more extensive options for a combined flow + boolean together in one package - a lot of times plug-ins are the best way for me to make a tool that kind of combines several different things together.
4363.135 In reply to 4363.134
I can hardly wait!!!!!!
Michael T.
4363.136
Awesome Michael :)
Looking forward to Version 3 Beta.
Nigel
Homepages: 3dkiwi.co.nz & C4D Cafe
4363.137 In reply to 4363.132
Hi Michael...
See image below :
Please read my question on those image....
Thank you
Did a google scholar search for (nurbs surface uv mapping), and also for (nurbs composition mapping).
Came across interesting papers, and even a few interesting patents.
(Cannot understand most of it.)
I am looking forward to Flow and MoI3!
EDITED: 27 Mar 2012 by BEMFARMER
4363.139 In reply to 4363.137
Hi Anis - you write that "the 2 faces already join as a single surface" - but no that's not quite accurate. They join together into a "Joined surface" which is an object made up of several faces joined together. But that's not the same thing as an actual "single surface" which means just 1 face. The way the model structure works each face that you see in the model has its own surface underneath it, so if you have more than 1 face that means that you have more than one surface as well.
So no the surface to surface mapping would not work for applying directly to the penguin belly as you have shown there.
But there are a variety of things you can still do - since that area is mostly curved just in one direction probably a curve to curve flow would work for that area rather than a surface to surface one.
Also you could create a single surface across that area by various techniques like projecting some lines onto there and the lofting them.
Also at some point I want to add in a tool that will let you merge 2 surfaces that share a common natural trim edge into one larger surface.
4363.140
Michael, I have to say - that's sick and twisted! ;-)
I mean, "sick and twisted" in a fiendishly clever and diabolical world taking-over kind of way!
...ohhh, the possibilities.
If you wanted to put type on two surfaces at one like that penguin's belly, could one just cut the type on the plane in two representative sections and wrap them on the two respective surfaces?
Is there some measure to control on where things line up and are positioned once processed?
4363.141 In reply to 4363.137
Anis, Really like the penguin! Some subtle stuff going on with the shape of the body and was wondering how you created it. Care to put together a tutorial?
4363.142 In reply to 4363.140
Hi Mike,
Yeah that would probably work.
It's controlled by the position of the object inside of the base plane.
For example - position the object so that it touches the edge of the base plane, then the morphed result will touch the edge of the target surface after it is processed.
Position the object in the center of the base plane, and it would go in the center of the target surface, etc...
4363.143 In reply to 4363.142
Very good! :-)
4363.144 In reply to 4363.143
Hi Micheal, flow looks awesome!
It's great to see you're back to work on the functions.
Some cool modeling time on the forecast!
Marc
4363.145
Oh, the anticipation :D
The Flow command keeps getting better and better lol
4363.146 In reply to 4363.145
I am anticipating the introduction of the flow command to be followed by a multitude of requests to control "How it flows and morphs!!" :o
4363.147 In reply to 4363.146
Hi Burr, well the base and target surfaces are what controls it.
It's kind of like texture mapping - objects are mapped from the UV space of the base surface into the UV space of the target surface.
If the target surface has areas where the UV space is compressed or expanded then the shapes will compress or expand in those areas as well.
If you need to have a whole lot of control over it, it may be that you would want to more directly model the output shape rather than using the Flow tool to morph it. But if your target surface is pretty well behaved (like if it doesn't pinch or expand irregularly) then the Flow command should be pretty convenient to use.
4363.148 In reply to 4363.147
I'll wonder about "Make a texture map in poly modeler, then use ZSurf to make a NURBS surface of it, then map the ZSurf surface to object.... Whalla!!! Texture mapping in MoI!!! lol
4363.149 In reply to 4363.148
A visit to the aquarium today confirms it.... MoI on the brain!!!!
It's close.... Very close.......:o
(Note the scientific name.... Could it be any more ironic???)
4363.150 In reply to 4363.148
Hi Burr, that process could actually work!
But you could also generate some insanely complex surfaces from it that may bog things down too much.
The surface that ZSurf generates is already pretty heavy itself - if you then try to morph a really pretty heavy surface onto something else, the morphed surface will generally get more complex yet as it will be trying to reconstruct the surface and fitting it to the deformation.
4363.151 In reply to 4363.149
Cool another kind of moi! :)
4363.152 In reply to 4363.150
Surely as you've stated, it would just be better done in a poly app... (But be sure I'll be trying it! hahahaaaa.)
4363.153 In reply to 4363.149
Wow very cool.
You know in french, Moi mean me.
Denis
| CorelDraw Grahics Suite X5 | Daz Carrara Pro 8 | Moi 3D V2 |
Show messages:  1-13  …  74-93  94-113  114-133  134-153  154-173  174-193  194-213  …  234-250
