Do you feel it?
 1  …  82-101  102-121  122-141  142-161  162-181  …  242-250
4363.122
Anis, would it be possible for you to create the ring in MoI, and create the scorpion in a polygon modelling software package, and then apply the scorpion as a displacement map onto the surface of the ring in your polygon software?
4363.123 In reply to 4363.122
Hi Michael...
Thanks for your detail for your current plan. MoI with its own flow command is already a good modeling choice :).
Hi NightCabbage,
I just found the ring picture on the web, so I dont know how to map the scorpion. But as far I know, delcam powershape can map a mesh on to surface.
thanks
re: Flow - I've managed to get the surface-to-surface flow working with a lot better quality.
You basically set up some objects and have them arranged on a base plane, then you run the Flow command, pick the base plane and then pick the target surface and the objects morph from the base surface to the same relation on the target surface.
Here are some examples:
Here's a pattern that was easy to do all flat:
Then using a sphere or a tube as the target surface:
Will give a result like this:
Now I actually need to get the curve-to-curve one (flowing between base spine curve to target spine curve) up to the same level of quality. At the moment the surface to surface one is actually working best, the curve-to-curve one is still a bit lumpy.
This stuff:
Mapped on to a sphere:
Some kind of crazy things are possible - here's a box pattern thing:
Mapped on to a curly cue thing that was itself a tube that was mapped on to a sphere (from the previous post):
Some text spackled on as well:
4363.128 In reply to 4363.127
Very cool.... :)
I think SWX, INVENTOR, SolidEdge dont have this feature, MoI win here :)
Thanks Michael....
4363.129 In reply to 4363.124
Hi Michael...
How if the target surface contains several faces, base on your example the target surface in only single face ( sphere, tabular... ) ?
Thank you...
4363.130
How will it be placed. Will it be possible to move it on the surface, or can it be scaled. Perhabs, when the originial will be conserved, moving it to X the copy also will move to X and so on.
Rudl
4363.131 In reply to 4363.127
Wow - what an awesome addition to MoI!
This will get me a lot closer to the functionality I've been looking for.
Will there be a way to inset and subtract the applied object? That is, wrap text onto a sphere and make it look like it is engraved (recessed) into the sphere?
I see how this could be done as a multi-step manual process after the letters are morphed, but it would be cool to have function that does this.
Basically it would be used as a "Stamping Tool" that would stamp any pattern into an object.
Ed
4363.132 In reply to 4363.129
Hi Anis,
The mapping is between a base surface and a target surface - meaning 1 single base surface and 1 single target surface. When you have an object made up of multiple faces there is one separate surface for each face so that means you can target just one face in a situation like that.
It will best be used to target a somewhat broader and larger piece of a multi-surface object. Usually it is best for smooth shaped areas of a model to be made out of one large surface anyway though instead of out of a bunch of little separate faces.
4363.133 In reply to 4363.130
Hi Rudl,
It is placed on to the target surface in the same relation that it has to the base plane.
So you can adjust the position of either the object inside of that plane, or increase the size of the plane itself to alter how it ends up being placed on to the target surface.
You would move or scale the base object around inside of its base plane to do stuff like that.
It will be possible to enable history updates so that you could change the original object and see the result update.
4363.134 In reply to 4363.131
Hi Ed,
Yes, you just use the regular Boolean commands after you've made the transformed object.
Use Boolean difference for example to cut the objects away from the base, or Boolean union to cut off the interior parts and leave the pieces that protrude to the outside.
It's just one more step to use the boolean command to get what you need after the transformation.
Adding too many things directly into a single command that can already be handled by a combination of some existing tools tends to make that command get complicated and end up with too many options inside of it.
It just generally helps to keep complexity down when you can use a couple of different commands in combination with one another to get the final result that you need. That helps make each individual command a bit more simple with fewer stages and UI within each one.
It's the same reason why there isn't a Boolean option built into other transform commands like the rotate or move commands, etc...
But maybe that could eventually be a plug-in that had more extensive options for a combined flow + boolean together in one package - a lot of times plug-ins are the best way for me to make a tool that kind of combines several different things together.
4363.135 In reply to 4363.134
I can hardly wait!!!!!!
Michael T.
4363.136
Awesome Michael :)
Looking forward to Version 3 Beta.
Nigel
Homepages: 3dkiwi.co.nz & C4D Cafe
4363.137 In reply to 4363.132
Hi Michael...
See image below :
Please read my question on those image....
Thank you
Did a google scholar search for (nurbs surface uv mapping), and also for (nurbs composition mapping).
Came across interesting papers, and even a few interesting patents.
(Cannot understand most of it.)
I am looking forward to Flow and MoI3!
EDITED: 27 Mar 2012 by BEMFARMER
4363.139 In reply to 4363.137
Hi Anis - you write that "the 2 faces already join as a single surface" - but no that's not quite accurate. They join together into a "Joined surface" which is an object made up of several faces joined together. But that's not the same thing as an actual "single surface" which means just 1 face. The way the model structure works each face that you see in the model has its own surface underneath it, so if you have more than 1 face that means that you have more than one surface as well.
So no the surface to surface mapping would not work for applying directly to the penguin belly as you have shown there.
But there are a variety of things you can still do - since that area is mostly curved just in one direction probably a curve to curve flow would work for that area rather than a surface to surface one.
Also you could create a single surface across that area by various techniques like projecting some lines onto there and the lofting them.
Also at some point I want to add in a tool that will let you merge 2 surfaces that share a common natural trim edge into one larger surface.
4363.140
Michael, I have to say - that's sick and twisted! ;-)
I mean, "sick and twisted" in a fiendishly clever and diabolical world taking-over kind of way!
...ohhh, the possibilities.
If you wanted to put type on two surfaces at one like that penguin's belly, could one just cut the type on the plane in two representative sections and wrap them on the two respective surfaces?
Is there some measure to control on where things line up and are positioned once processed?
4363.141 In reply to 4363.137
Anis, Really like the penguin! Some subtle stuff going on with the shape of the body and was wondering how you created it. Care to put together a tutorial?
Show messages:  1  …  62-81  82-101  102-121  122-141  142-161  162-181  182-201  …  242-250
