3Ds Max Patch Modeling
 1-10  11-30
4360.11
Thank you very much Michael for your thoughtful explanation.
I used CorelDRAW for graphic design with its anti-aliased BeziƩr curves for the last 20 year so when I found MoI I took to it like a duck to water.
It feels comfortable to work with.
Consequently, I've used Sketchup for a few years, and though it is a polygon based modeler, their approach is based upon building shapes out from each other.
It's easy to draw a shape in 2D on the planar surface of one object and refine it into a more complex one. It's strong suit lies in its "Follow Me" tool, though that tool is limited. I've used a myriad of plug-ins to do features like skinning and more organic shapes.
Ah... but Sketchup can get "polygon heavy" very quickly and it was frustrating dealing with beaucoups of misplaced edges and permanent "sticky" elements.
Sketchup does have strong abilities in Boolean and sweep functions, so I know what you mean by creating larger master objects and cutting away from them to refine the model.
Somewhere in my self-teaching and mindset I desired to craft shapes of an exact nature to be satisfied, so I got used to creating meshes and piecing them together.
I was crafting this pedestal sink basin last night and first used a sweep of four profiles between two closed rings, one a super-ellipsoid made with the Conic tool.
The results were okay, but had ripples in it that radiated from the center. The faucet shelf was okay, but I desired a more flat shape.
I created the lines to make that shape, but would have to resort in using Meshes instead of the Sweep. And in succession, Joined them together.
It left me with the hard edges I've run into before. Wish I could get rid of them, as they show up in renders.
I've also considered fabricating the bottom half of the basin from a solid sweep, then making one of the inside and Trimming it out to form in inner bowl with the Boolean function. Then applying a Fillet to the top rim and bottom hole.
However, I'm often now apprehensive to go that route as both the Fillet often fails to work on the edges of more curved shapes and sometimes the Trimming function does not leave the inside wall that I wanted.
I can do a reach-around with other Boolean functions with some cutting and pasting though.
It's not all a deal breaker. MoI does the job, and it is as easy to operate as the natural media application known as ArtRage.
Thanks for providing the "NoSave" version. I'll be able to feed my MoI addiction until the funds are there.
(In pic below: The left ones are made from Sweeping profiles. I wanted a more specific shape for the back so I made the right ones from Network meshes - Notice the visibility of the sharp intermediate edges)
Mike
4360.12 In reply to 4360.11
Hi Mike, yeah SketchUp is great for boxy objects, but trying to deal with curved objects is awkward with it since it is hard to manage piles of little edges and facets that are trying to approximate curved areas.
re: panels - can you please also post the 3DM file that goes along with your screenshot so I can inspect the actual geometry?
But basically if you built it by making something like each quadrant as a separate Network surface, then that's normal that they won't naturally be smooth where they touch - that's because when you build any kind of shape, whether it's a curve or a surface if it just comes to an end it won't have any knowledge of what kind of shape is supposed to be coming after it's end. Usually the solution to this is to build it as a larger surface all in one shot rather than in totaly separate pieces.
Here are a couple of examples that show the difference with making a shape that stops at a single point as compared to a longer continuing one:
http://moi3d.com/forum/index.php?webtag=MOI&msg=1398.18
http://moi3d.com/forum/index.php?webtag=MOI&msg=1398.19
Like I mentioned previously, I do want to add some tools in the future for smoothing out a surface that was built in a piece by piece method, but even at that point you will likely be better off using the "build a larger smooth surface in one go" method since it just naturally makes a smooth object and building in individual separate patches naturally makes shapes that come to an abrupt end.
The other ways that you can get smoothness is by leaving some space between objects and using the Blend command which puts in a smooth connector surface in between the space between 2 edges, or by building things with some initially sharp corners and then using fillets to smooth them out.
But for your sink to get a smooth shape most likely your best bet would be to get the whole revolution done in one surface creation command rather than only doing one quadrant at a time.
4360.13
Thanks Michael,
That makes very good sense and it will be an interesting and fun challenge to implement the "whole piece" strategy.
I also discovered that you can make meshes out of larger sets of curves! As long as they form some type of logical grid.
I knew about this ability already, I just have to think more ahead to use it.
And thanks for the examples.
Mike
4360.14 In reply to 4360.13
Hi Mike, thanks for attaching the example file.
So I took your curves for the outer surface and joined the elliptical looking pieces together so that there were 6 curves with 2 closed ones (see attached 3DM file). Those curves are all already all nice and smooth with each other (they may have been cut up pieces of one original curve to start with?) so without needing to any other editing other than that joining, you can then build a Network through that whole thing at once, giving this result here:
Looking at that from the underside:
And now compare that to the same outer surface shape in your original model that you did as 4 separate networks rather than all at once:
So that's a pretty good example right there of how to avoid that kind of crease lines appearing between panels - it's generally easier to make things smooth when you build the piece you want to have smooth as all one big surface more like this...
Hope this helps! Sink forms can pretty difficult models to handle where they kind of thicken and change shape in the back part.
4360.15 In reply to 4360.9
Thanks again for your time in answering all these basic questions. Now for one more!
What determines the number of points on a surface when you click show points?
For example a default sphere shows 86 points. Since there are an infinite number of points on a surface I have a feeling MOI shows the least number of points possible in order to represent the curvature of the surface but still be workable. Is my assumption correct?
4360.16 In reply to 4360.15
"What determines the number of points on a surface when you click show points?"
It's the number of control points of that you have yourself created when you have drawn your curves ;)
So your number of clicks if you have used a mouse ;)
Then multiply when you make a command betwen these curves (Sweep for example)
And surely yes the minimum for the surface will be the more approached according the curves
For the sphere I believe the number of points is the less reasonable number for a primitive for future rich deformations ;)
Because a sphere's surface can have only 28 control points !
EDITED: 30 Jun 2011 by PILOU
4360.17 In reply to 4360.16
I wonder if there would be a way to make a Rebuild command for surfaces like there is for curves.
Then you could get more points to work with if you wanted them.
4360.18
It might be easier to edit the number of control points or edit the points in the original edge curves before re-Meshing.
Michael,
Here is the same sink done in ONE MESH action. I'm amazed!
I took the profile shapes and added profile rings to allow the Mesh function to follow along.
So the path follows from one drain ring, around the sink, and back to the bottom drain ring.
I now have a seamless solid shape with (nearly) perfect surface contours.
Thanks for the insight!
Mike
(Framework on left consisting of open shaped vertical profiles and closed rings to follow them. Single Mesh result on right)
4360.19 In reply to 4360.15
Hi Shaun,
It depends on what technique was used to construct the surface - some surface construction techniques will create a surface that directly inherit the control point structure of the curves that were used to generate them, while some other construction methods may go through a kind of fitting process where the surface is refined until it reaches a particular level of accuracy.
Yeah, actually a sphere is a special case - the sphere internally uses the minimum number of points needed to make an exact sphere surface but that does not allow for very good squishing, so when you turn on control points for a sphere it actually shows you the control points for a rebuilt version of the sphere with more points around it. In the future I want to make the number adjustable.
You can actually build a custom sphere with a particular number of points in it right now - to do that you would set up an equator circle and a vertical arc (see attached 3DM file) then use Rebuild on them with the # of points mode to set those curves up with the number of control points you want to have in the final sphere, and then create the custom sphere by using Construct > Revolve > Rail revolve - pick the vertical arc as the profile curve and the equator circle as the rail path, and then pick the revolve axis as the line between the endpoints of the vertical circle and you'll have a sphere with that number of points in it as the result.
If you want to build a flat plane with a particular number of points in it, you can use the Extrude command with the "Set path" option for that, see here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=1313.2
4360.20 In reply to 4360.15
Also re: spheres - MoI will only show you the "auto-rebuilt" control points for a sphere that is a full surface that does not have any trimmed out areas in it.
If you trim away a little piece of the sphere and then turn on control points, you'll then actually see the sphere's natural control points which look like this:
These points don't deform well though - it's basically 8 chunks kind of glued together and if you disturb these points you can easily make a sharp crease appear between the sections - that's why MoI will show you the control points for a rebuilt sphere instead when it is able to.
4360.21 In reply to 4360.17
Hi Shaun,
Yup, that should be possible in the future - also it will be possible to extend Add pt to surfaces for adding in an extra line of points to one area of the surface. The way NURBS surfaces work they are always a rectangular grid of points though so you can't just add in a single point somewhere, you have to add in an entire row or column of points.
Basically surface control point editing is not a fully fleshed out area in MoI yet - because things like Boolean and cutting operations are the greatest strong areas of NURBS modeling, I've focused more attention on those strongest areas first.
The basic assumption is that if you like to do surface point editing, you will likely be doing that in sub-d modeling program instead of in MoI, since that is the strong area of sub-d modeling.
As time goes on I will continue to flesh out the surface control point manipulation toolset a bit at a time, but it's fundamentally limited because of that topological restriction I mentioned above where you can't just insert a single point anywhere you want, with NURBS you have to insert an entire row of points since a NURBS surface is defined by a rectangular grid of points. This places a big constraint on point topology, and it's the biggest reason why sub-d modeling became the method to use for that type of point cage manipulation modeling rather than NURBS surfaces.
4360.22 In reply to 4360.18
Hi Mike,
You're welcome, and that looks like a great improvement in your shape!
4360.23 In reply to 4360.21
"also it will be possible to extend Add pt to surfaces for adding in an extra line of points to one area of the surface"
Now we're cooking!
4360.24 In reply to 4360.23
You can also just "Project" a line to the surface ;)
4360.25 In reply to 4360.24
Actually what I think he's saying is we may get the ability to increase the number of points that define the surface. Not adding a curve to the surface like a projection.
4360.26 In reply to 4360.25
Hi Shaun, yup that's what I meant.
4360.27
Thought I'd post a pic of how the sink object was used.
I'm happy to have done so much with it the trial time I had left, learned a lot.
In due time, I'd like to do a good quality render.
Kind of obnoxious for a bathroom sink, but it's the result of how MoI can allow quick visualization of an idea. (plug ;-) )
4360.28 In reply to 4360.27
Hi Mike, wow you made a ton of progress, including the mechanics! That's a great result!
4360.29 In reply to 4360.27
Sweet concept Mike! I like it a lot.
4360.30 In reply to 4360.29
Thanks guys!!! :-)
Show messages:  1-10  11-30
