How to get smooth surfaces
All  1-10  11
4357.11 In reply to 4357.9
""""""""Also, in software that supports extensive surface continuity, like Solidworks, that I use, a lot of times SW will refuse to create the surface, """""""""""""
Yeah, you can see this in the file I just posted also. test_surface zip.. If you run the blend and start to move the g2 bulge value, you will see the little corner patch go first..
Show messages: All  1-10  11
